Latest: sparrowdclxvi
Overall: 17139
Online Now [118]:
Visitors: 117
Today: 4491
Total: 113010249
Forums › The Car › 206 Talk › Lowering????
Lowering????
19Connor92
PostPosted: Thu May 30, 2013 12:51 pm Up
What are the best value for money coilovers?
or What are the best springs?
PezHdi
PostPosted: Thu May 30, 2013 2:21 pm Up
Depends on what you going for really.
Looks :T. here are many types of coilovers.
Cheap ones are real s**t . But if your not using then for Preformance then why not Smile
The more you pay the better quality they are.
Iv heard that coilovers make the ride really choppy.
Preformance wise
Springs I'd go H&R or Eibach,
If you want more the Bilstein or H&R shocks Smile
Again the more you pay the better quality.
Iv got Bilstein & Eibach set up on mine and it handles brillianty.
I also no tht Koni FsD's are also a good set up as my mate has them (on his A3 mind)
Hope this helps you,
Also search this site there are loads of lowering questions and answers
Search button is your friend Smile
EXL Pez
19Connor92
PostPosted: Thu May 30, 2013 3:02 pm Up
Yes thanks mate was looking at eibach and it says there are 4 springs in the kit? lowering the back? got a GTI 180 and its a torsion bar at the back? might go for Koni 35mm. What you recon
PezHdi
PostPosted: Thu May 30, 2013 3:58 pm Up
There are no springs on the back, the Eibach kit is only 2 springs.
I also have a 180 rear axel rebuilt by IM axle,
You have to adjust the torsion bars to get the drop at the rear Smile
Also remember the Gti 180 axle is lower than a standard one by about 10mm I think it was when I measured it Smile so 35 mm will be plenty as that's what I have done.
If I was you I would go 30mm on the rear Smile
At the end of the day the choice is yours to make mate.
EXL Pez
RedHDI
PostPosted: Fri May 31, 2013 5:30 am Up
FK Coilovers are good
