Latest: tebas93089
Overall: 17179
Online Now [77]:
Visitors: 76
Today: 39197
Total: 137811072
Forums › The Car › 206 Problems › air con fuse?
air con fuse?
brinylonshirt
PostPosted: Fri May 31, 2013 8:32 am Up
My air con won`t work after taking the car off the road for a month.
I looked at fuses first, and found a 40 amp loose inside the cover. Can`t find where this fuse should go, it says Number 18 on the diagram but I can`t find a number 18?!?! Green light comes on but no noise whatsoever from the rest of the system.
Where next to look please anyone??
PostPosted: Fri May 31, 2013 8:38 am Up
Pre plex or plexed?
Air con is better looked at by an expert.
PostPosted: Fri May 31, 2013 8:55 am Up
macca1411 wrote:
Pre plex or plexed?
+1
Pug A/C is actually quite good and v. reliable when sorted properly, and a specialist will save you money and hassle in the long run.
jk206
PostPosted: Fri May 31, 2013 9:40 am Up
Well on my 02 plate 206 when I pressed the a/c button the light lit up but no clicks or noises, got the system re gassed las year and now it clicks when the button is pressed and the a/c works perfectly. So it could be that
brinylonshirt
PostPosted: Fri May 31, 2013 9:51 am Up
Cheers. I`ve never known the system to just stop due to needing refilled, but I will look into that.
marianomalen
PostPosted: Fri May 31, 2013 11:04 am Up
macca1411 wrote:
Pre plex or plexed?
i agree, if I were you i will take the car to a mechanic
good luck Very Happy
