Latest: tebas93089
Overall: 17179
Online Now [57]:
Visitors: 56
Today: 6723
Total: 138153849
Forums › The Car › 206 Problems › Engine swap PLEASE HELP
Go to page 1, 2, 3  Next
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 1:11 pm Up
Hey guys,
So i bought a vtr engine for my 1.1 206 engine swap and i have hit a rather large barrier with the engine looms as my new ecu wont fit the 1.1 loom and the new 1.6 vtr loom wont fit the 1.1 fuse box i am in a right spot of trouble and have been swapping round sensors from the 1.1 onto the 1.6 block but i suspect doing so will either one make it not run at all or two run very lumpy and slow because of it thinking there is a 1.1 instead of a 1.6 if anyone could help me out that would be great or if anyone knows a loom that would fit that would solve it all i thought maybe the 1.6 glx loom could work but dont have anyone around me who has one so i cant check! thanks in advance for your help!
PostPosted: Sun Jun 02, 2013 1:25 pm Up
What do you mean it doesn't fit the fuse box?
PostPosted: Sun Jun 02, 2013 1:47 pm Up
Its not a straight swap, you should, and will need to swap ECU and Immobiliser from the saxo.
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 1:51 pm Up
ill post a photo in a few mins on what my issues are!
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 1:59 pm Up
here is the different plug from the vtr to the 1.1 fuse box.
and here is the different ecu's and plugs
PostPosted: Sun Jun 02, 2013 2:07 pm Up
That plug doesnt go to the fusebox, it goes to by the bottom of the airbox
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 2:08 pm Up
images are up now mate cheers
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 2:14 pm Up
there is no plug on the airbox i have :S
PostPosted: Sun Jun 02, 2013 2:40 pm Up
By the bottom, not on the airbox. Look behind the front bumper down low on the passenger side.
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 2:48 pm Up
i still cant see where this plug is supposed to go, that plug is supposed to go where there is no plig pluged in on the fuse box there is no loom on my 1.1 where that can plug in the only wire that goes down passenger side by the bumper is the fog light :/
PostPosted: Sun Jun 02, 2013 3:21 pm Up
when you swap engines,it's always recommended to have the donor car close to you,and swap engine,and engine loom,ECU,fuse box,and everything related to make this work,this way u will have a great finish,and a free problem car.
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 3:27 pm Up
i have the car close by, the fuse box in the saxo is also incompatible with the loom on my car :/ as my fuse box has plugs for the battery lights and everything els where as the saxos box doesnt i think im going to have to get a loom of a 1.6 hid or glx 206 to get this to work :/
HDI90
PostPosted: Sun Jun 02, 2013 4:18 pm Up
For a starts yours is multi plex and saxos aint so you will have problems there
GTI 180
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 4:29 pm Up
any way around this or should i just give up on the idea? :/
DylanAWRoberts
PostPosted: Sun Jun 02, 2013 4:32 pm Up
if i get the loom of this model could i just bipass all these issues? the ecu on this car looks the same as my 1.6 ecu or would i need both the ecu and loom?
Page 1 of 3
