Latest: tbafonso
Overall: 17130
Online Now [42]:
Visitors: 41
Today: 12047
Total: 103834373
Forums › The Car › 206 Problems › Anti pollution fault 2.0hdi 206. 2002
Delo
PostPosted: Sun May 19, 2013 3:21 pm Up
Anti pollution fault 2.0hdi 206. 2002 . No signs of anything wrong other than em light on . Need to get sorted before mot . Anyone one in Kent got diagnostics to check why on? What possible causes?
Cheers Del
206
PostPosted: Sun May 19, 2013 3:35 pm Up
Could be one of a million things, and not necessarily related to the emissions.
Delo
PostPosted: Sun May 19, 2013 3:57 pm Up
Anyone in Kent got diagnostics machine.?
206
DREWDEN
PostPosted: Sun May 19, 2013 4:02 pm Up
Same engine as yourself, had this problem a while back, (good mechanic) told me cat was blocked, no diagnostics on it at that point.
Was told to give it a good thrashing, low gears, high revs, light went off hour later.
Worth a try, but like steve says could be other things.
I now put 10k boost power restorer every 6 months through the air inlet, all the s**te that comes out is unbelievable. Failed emmisions last MOT this sorted it.
206 2ltr Hdi glx 53 plate
eddie206
PostPosted: Sun May 19, 2013 11:19 pm Up
DREWDEN...whats this 10k boost power restorer you mention man???ive heard of this as a fuel additive but you say thru the air inlet???im guessin its a spray of some sort???
does it work on the petrol 138gti model as i have anti pollution fault and an easy fix would be nice?...
DREWDEN
PostPosted: Mon May 20, 2013 6:07 am Up
Must point out, i first tried a fuel additive product first from GFS, £14 which i was, assured would work, failed miserably after a MOT retest.
I then went to a mechanic i use, and he guaranteed me to use this stuff £25.
Used half the can (spray) and flew through emissions test.
Just looked at package and is made by Granville, and can buy it for petrol or diesel
eddie206
PostPosted: Mon May 20, 2013 2:49 pm Up
Ok. Granville power boost restorer..
would you say this is a quik fix to pass the emmisions test or will the positive results last long term?
DREWDEN
PostPosted: Wed May 22, 2013 3:54 pm Up
No not a quick fix, blasts all the crap out of the system thats been building up over time, a lot of taxi drivers use it as well because they do a lot of town driving.
DREWDEN
PostPosted: Fri May 24, 2013 10:40 am Up
Have you tried this stuff yet eddie 206, if you have, just wondered what your thoughts are.
bbunce1991
PostPosted: Fri May 24, 2013 6:23 pm Up
I've used it not too long ago. Not muck black smoke came out back so suppose engine pretty clean. Seemed a bit poker than before ... Was worth the fiver from Halfords.
Brad
DREWDEN
PostPosted: Sat May 25, 2013 6:23 pm Up
Brad
Didn't know Halfords did it, thanks for that.
Ye loads of black fumes come out.
bbunce1991
PostPosted: Sun May 26, 2013 3:51 am Up
Yea, I don't think they do anymore though, was in a clearance section. However worth a look mate.
Brad
eddie206
PostPosted: Tue May 28, 2013 5:46 pm Up
I will be using this very soon as its almost the end of the fourth week and im gettin everything done..mot,brakes,tyres,emmisions,tax,service,fuel smell,the lot......its all well overdue(except tax end of this)and i will let u know...if it fails on emmisions and i blast the granville 10k boost to see what occurs.
Delo
PostPosted: Sun Jun 02, 2013 3:01 pm Up
FIXED.
Replaced brake sensor and replaced throttle sensor H20cooler reset my fault codes and no anti pollution fault anymore. Emlight no longer on.
Brake sensor was noticeably burnt out inside, throttle sensor requires special tool to access internallly so £20 one from breakers seems to work fine.
206
