Online Now [909]:
Visitors: 908
Today: 41512
Total: 146186751
Forums › The Car › 206 Problems › fan does not come at all
julian206gti
PostPosted: Mon Jun 03, 2013 12:49 pm Up
Hi everyone
New to the forum but hoping you guys can help point i the right direction.
I bought a 206 gti last year and have sorted what i thought were all the issues. But now it warm noticed fan does not work at all. So we have to have air con at 28c to stop it overheating. Any ideas was going to check resistance but dont what valie i should be looking for . Also where can i locate the temp sensor that works the fan and also is there owt else it could be.
Thanks for any help given
PostPosted: Mon Jun 03, 2013 1:05 pm Up
the temp. sensor always located close to the thermostat housing,have you changed the thermostat since the day you bought it?
julian206gti
PostPosted: Mon Jun 03, 2013 1:13 pm Up
Not since i bought whereabouts is it located. Is it the coil/ sensor located next to the fan.
Thanks julian
PostPosted: Mon Jun 03, 2013 1:31 pm Up
You could also check the connections at the fan, they are prone to corrosion.
julian206gti
PostPosted: Mon Jun 03, 2013 1:33 pm Up
Was about to check the connection . Any ideas as to where the temp sensor is located cant find and i dont have an engine diagram
PostPosted: Mon Jun 03, 2013 1:51 pm Up
Why do you need to run the A/C at 28 for the fan? The slow speed fan should come on as soon as the A/C is turned on.
julian206gti
PostPosted: Mon Jun 03, 2013 1:55 pm Up
Fan does not come on at all even air con at low speed. Cleaned terminals to the fan little bit of corrosion but this has made no difference. Any ideas could it be the coolant sensor or fan itself. Is there a way of testing fan
julian206gti
PostPosted: Mon Jun 03, 2013 1:57 pm Up
Sorry last message not clear typing on phone. Fan doesnt work even with air con working at lowest temp 14c
Found having it set to 28c stop it overheating
julian206gti
PostPosted: Mon Jun 03, 2013 2:03 pm Up
Disconnected fan at the fan hosing and tested resistance with a multimeter but it does not give a stable it fluctuates between 37 and 42 ohms i would have thought the reading would be stable so could it be the fan afterall
ukskater01
PostPosted: Mon Jun 03, 2013 2:35 pm Up
You should try to power the fan with a direct feed from a battery. That way you can rule the fan out
julian206gti
PostPosted: Mon Jun 03, 2013 2:42 pm Up
thanks mate will try that tomorrow had to put front of car back together as missus uses it for work.
PostPosted: Mon Jun 03, 2013 3:22 pm Up
1) Disconnect the coolant temp sensor with the engine running and the fan should kick in.
2) Put the air con on at standstill and the fan should come on.
3) Remove the relays and also check the wiring to the relay holder. Most of the time the wires themselves are so corroded they are broken.
julian206gti
PostPosted: Mon Jun 03, 2013 6:08 pm Up
