Online Now [325]:
Visitors: 324
Today: 8424
Total: 142821943
Forums › The Car › 206 Problems › 206 hdi clicking under dash
Lowiee
PostPosted: Tue Jun 04, 2013 3:06 pm Up
hi everyone i need a bit of help or i,m just thick
just got a 206 hdi 2l turbo annoying thing is when i start the car there is a clicking noise from under the dash /driverside about 6-8 clicks then it stops the car does start and run fine no warning lights on the dash until its switched off the battery light is on until i take the key out any ideas
iainlovatt
PostPosted: Tue Jun 04, 2013 3:58 pm Up
Sounds like it could be a relay.
(My Garage)
Lowiee
PostPosted: Tue Jun 04, 2013 4:38 pm Up
thats what i thought cannot see any under there and i thought most of the relays were all built into the bsi unit
Lowiee
PostPosted: Wed Jun 05, 2013 3:45 am Up
a question regarding disconnecting the battery to trace the fault its a 206 2003 hdi if i disconnect it will i need the radio code i have read on another forum that these ones have a married radio to the vin and dont need it is this true cheers
Lowiee
PostPosted: Wed Jun 05, 2013 4:01 am Up
quick update the clicking has stopped after changing the aux belt and taking the tax disc of the windscreen ( temp put it up by the rear view mirror ) so cud be the rain sensor was being blocked the air con comes on auto now aswell
the battery light is still on after turning the engine off key back position 1 , not sure if there is something still live could it be the key fob battery or just earth point problem
thanks iainlovatt
PostPosted: Wed Jun 05, 2013 4:43 am Up
Your radio should be coded to the VIN, so disconnecting the battery shouldn't be a problem.
AFAIK the battery light should come on at position one. If the battery light stays on when the ignition is off, you have a problem.
As Iain says, the clicking sounds like a relay. There are a couple down by the drivers knee behind the fusebox panel. You could stick your head down there and see if you can identify which one is clicking.
Try a BSI reboot and check the alternator output. Both are painless to the wallet. It is possible that the aux belt was causing the problem. Did you replace it because it was slipping or just because of age?
Lowiee
PostPosted: Wed Jun 05, 2013 7:47 am Up
thanks macca 1411
ive checked the relays but it seems to have sorted it self so no more clicking after starting up i will try a bsi reboot just to be safe and i changed the aux belt because the power steering was stiff and the belt seemed to be slipping ive checked the alternator output and got 13.45 -14.25 volts at the battery
