Latest: ArtistKS
Overall: 17145
Online Now [99]:
Visitors: 98
Today: 14808
Total: 115887978
Forums › The Car › 206 Problems › clutch cabel problems!!
vickired
PostPosted: Sun Jun 02, 2013 5:18 am Up
The clutch cable snapped on my car. I had a new clutch cable fitted but now clutch pedal sits higher than other pedals and bite is very high and car now struggles to get up hills as if clutch is still on. the garage checked my clutch a couple of weeks ago and said it was fine.
Deckchair5
PostPosted: Sun Jun 02, 2013 7:12 am Up
Go with your own experiences, you know the bite is high, not necessarily a problem in itself, but it's not transmitting drive and feels like it's still on the biting point when going uphilll and that IS very bad as it will burn out the clutch in no time
The clutch "being all right" as your garage says isn't the problem, it's where the biting point is.
Fitting the new type cables requires some thought and it's very easy for someone to have installed that incorrectly if they didn't follow the instructions implicitly. That would result in exactly the symptoms you have of clutch biting too high and clutch not fully engaging.
A test might be to put handbrake on tightly and then try to move off in 2nd perhaps. If the engine doesn't die away then the clutch isn't engaging properly. You sound like you're already experiencing this on hills, if you smell burning going uphill then don't drive the car much at all until you get it sorted
IF the new cable was installed incorrectly then more often the only remedy is to fit another new cable as they are a sort of one time snap fit and take up the slack in one direction only, all in one go. I know a lot of mechanics were surprised by the design of these new cables. They were designed to make installation easier but you have to follow the instructions rigidly or else it's all ruined. Any technician that goes into it with a feeling of "I've fitted plenty of clutch cables before so I don't need to read the instructions" is going to have an expensive time at £30 a cable (or they are going to try to convince the customer that nothing is wrong with their fitting Embarassed )
The clutch pedal height can be adjusted on some models but you'd need to get the cable installed properly first THEN adjust the pedal height to suit you
vickired
PostPosted: Sun Jun 02, 2013 2:49 pm Up
Hi thanks I'm getting a new clutch cable fitted tomorrow so see if that works
Thank u
vickired
PostPosted: Mon Jun 03, 2013 4:29 pm Up
Had another clutch cable fitted and still the same. So definetly need the clutch doing!
20Drift
PostPosted: Mon Jun 03, 2013 4:59 pm Up
Have you checked the clutch pedal auto-adjust mechanism? Could explain the high position of the pedal - not sure if it would affect the bite point as well though
Deckchair5
PostPosted: Mon Jun 03, 2013 5:41 pm Up
I can't understand how your garage said the clutch was all right 2 weeks ago and now it isn't, that doesn't make sense. Very suspicious.
But you can adjust the pedal height to be level by a 13mm adjust bolt on the actual pedal mechanism , just above the pedal itself on many 206's. You can on mine for sure. It doesn't affect the bite point though
pedal height adjuster<< click here
vickired
PostPosted: Tue Jun 04, 2013 2:58 am Up
Hi yes we've tried tightenening it but still the same. Been quoted 169.0 to 200.0 to fit a clutch kit!!
Deckchair5
PostPosted: Tue Jun 04, 2013 3:14 am Up
Yes that's about right, it'll feel nicer once it's done though
vickired
PostPosted: Sun Jun 09, 2013 4:41 pm Up
A quick update. My car went into have a new clutch and mechanic found a hole in gear box so having a new gearbox fitted. He said clutch was fine but I'd already bought clutch kit so having it fitted anyway.
Deckchair5
PostPosted: Mon Jun 10, 2013 1:03 am Up
Strewth! Well at least it's all going to be new in there now. Should be good when it's all finished
