Latest: Beduff1977
Overall: 17134
Online Now [362]:
Visitors: 361
Today: 73855
Total: 108596988
Forums › The Car › 206 Problems › Knocking Sound When Braking
jimbo1467
PostPosted: Sun Jun 09, 2013 5:22 pm Up
Hello, about a month ago i started hearing a noise coming from the front wheel drivers side and thought it must be the bearing, so i took it to my local garage where the mech said it could be the track rod or springs, so after he looked at it he agreed yeah it was the bearing, so he changed the bearing for £80. After driving away from the garage and taking it for a test drive to see if everything was ok when braking i heard a knocking noise, it only made this sound when i braked and only from the drivers side front. I took it back the next day as the garage was shut by the time i got back and the mech looked at it again. After another two times of getting it back and him saying he`s fixed the problem the knocking when braking was still there. The final time i took it back he put new brake pads and discs and another bearing free of charge on which seemed to stop the noise.
Two weeks later and the noise has come back.
Can any of you good ppl shed any light what might be the problem ?
Peugeot 206 S Reg
GLX
1.4
Petrol
jimbo Smile
Lowiee
PostPosted: Mon Jun 10, 2013 5:20 am Up
do you get vibration on the brake pedal at the same time the disc /caliper might be loose , abs unit failing
just a noise you hear i would check the driveshaft and all the ball joints wheel bearing on tht side
jimbo1467
PostPosted: Mon Jun 10, 2013 11:02 am Up
Nope no vibration on brake pedal, brakes work perfectly. The noise is deffo like something hitting off something as the wheel goes round and only when i use the brakes, cheers for answering.
jimbo Smile
Lowiee
PostPosted: Mon Jun 10, 2013 12:46 pm Up
check your wheel is sitting properly and the nuts are tight
eddie206
PostPosted: Mon Jun 10, 2013 12:51 pm Up
Has anyone else driven the car,because sometimes these noises sound luke they are from one side but infact its the opposite side...try someone elses opinion while driving...
Did you change both sides discs and pads because it sounds like a warped/bent disc to me..maybe on the opposite side if it hasnt been done??
jimbo1467
PostPosted: Tue Jun 11, 2013 6:28 pm Up
Thnx for replying, yeah the wheel is sitting properly and nuts are tight. No no one else has driven it, both discs and pads were changed, the mech said the first disc on the drivers side wasnt warped either but he changed it just incase. Yeah its stumped me too, i keep thinking it a loose pad that isnt sitting correctly. Thnx again for replying.
jimbo Smile
eddie206
PostPosted: Wed Jun 12, 2013 3:44 pm Up
Is the very first noise the same as the rest of the time and the same as what you have now???describe the noise mate...
jimbo1467
PostPosted: Thu Jun 13, 2013 8:57 am Up
Hi eddie thnx for replying, the noise is like a grinding noise and i hear it when i brake. It`s like something is hitting off the disc when the wheel turns only whilst braking and yes the noise is the same. Before the first time i went to the garage it was a knocking noise then he replaced the discs and pads and now the noise is a grinding noise.
jimbo Smile
PostPosted: Thu Jun 13, 2013 12:00 pm Up
Brake pads on the right way round?
PostPosted: Thu Jun 13, 2013 12:15 pm Up
Did the guy at the garage tell you how to bed in the new brakes?
GreenTrees
PostPosted: Thu Jun 13, 2013 3:22 pm Up
Sounds like a little stone caught up in there to me Wink
My wife\'s 1999 1.4 GLX
eddie206
PostPosted: Thu Jun 13, 2013 8:28 pm Up
As above to check then...and check the position of the heat shield too...if it only happens when you brake it must be a moving part of the BRAKES...
Does it happen every time you brake???
I would take the caliper off and copper grease the suited surtaces checking the pads direction and caliper piston function..
