Latest: jackrox1992
Overall: 17186
Online Now [686]:
Visitors: 685
Today: 93628
Total: 147815795
Forums › The Car › 206 Problems › Wheel Wobble
Wheel Wobble
Go to page Previous  1, 2, 3
Sim
PostPosted: Mon Jun 10, 2013 1:23 pm Up
First run the tests, before starting throwing any money in changing parts at random
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
Zack
PostPosted: Mon Jun 10, 2013 3:55 pm Up
Ok thank you so much for the videos
Sim
PostPosted: Mon Jun 10, 2013 5:02 pm Up
No probs mate, I know how you feel Smile
I wanted to change the world to bring my car roadworthy/comfy to drive asap Smile But inspecting and ruling out causes does save money and nerves (takes more time though, than just dropping off at the garage)
EV (roadtripper)
GTC VXR (sold)
novatron1_2
PostPosted: Thu Jun 13, 2013 6:09 am Up
sledge wrote:
Had this problem, after suspecting out-of-balance wheels / warped brake disk / wheel bearing, this forum helped to identify the cause: it was a buckled/warped wheel hub (the symptom was: strong steering wheel vibration when braking at high speeds).
You could see the wheel wobble:
www.youtube.com/watch?v=8yiQ0U50WdU
And the brake disk wobbles too (see gap between brake pads and disk):
www.youtube.com/watch?v=78sQBUto1JM
Problem gone once new wheel hub fitted:
www.youtube.com/watch?v=5S-xvrkgifE
Hope this helps in your tests
I had exactly the same problem, initially thought it was the discs but when I fitted the new ones and checked for run out it was still there. So I took them off and checked the run out of the hub, it was awful. I've never had a car before when the hub has buckled. A new ( £10 scrappy) hub solved it all.
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
Sim
PostPosted: Thu Jun 13, 2013 6:12 am Up
I tried new brake disks but did not have the dial indicator..
So the car with new brake disks does not shake for couple of weeks, until they go out of balance! That's how the previous owner sold me the car... and it cost cheap
EV (roadtripper)
GTC VXR (sold)
Page 3 of 3
