Latest: lio94
Overall: 17181
Online Now [334]:
Visitors: 333
Today: 76075
Total: 141715725
Forums › The Car › Solved 206 Problems › average speed stuck
average speed stuck
Lowiee
PostPosted: Sun Jun 16, 2013 8:25 am Up
has anyone had this on the MFD not really a problem
i have a multiline MFD with trip comp on a 2l hdi turbo 03 and as far as i can work out my mpg is all over the place and the avrg speed is stuck at 16 mph so heres the question are the sensors from the abs system running this i have looked up on service box and searched google and from what i understand the data used for the display readings are from the N/S front / rear abs sensors to the ecu to calculate the trip /speed / mpg readings
or is there another sensor somewhere i am unaware of
PostPosted: Sun Jun 16, 2013 9:06 am Up
Try a software reset, easiest and free
Lowiee
PostPosted: Sun Jun 16, 2013 9:21 am Up
i have tried the bsi reboot in the week while changing filters/oil testing fan sensor didnt seem to make a difference to the average speed still reading 16mph what i really need to know is is the sensors for the speed / trip / mpg data run via the abs sensors in the wheels if you get what i mean
Lowiee
PostPosted: Sun Jun 16, 2013 10:41 am Up
cheers Addaz i just did another bsi reboot and reset the trip system via the stalk now it seems to be working
