Online Now [1375]:
Visitors: 1374
Today: 38173
Total: 106375424
Forums › The Car › 206 Talk › What bolts and fittings for hub assembly
QuArTz
PostPosted: Mon Jun 17, 2013 3:53 pm Up
Trade Rating: +16
Can someone point me in the right direction for what size nuts and bolts I need to replace the ones which attach the various steering and suspention parts to the wheel hub.
I've recently had some work done in that area and who ever worked there before aloud the bolts and fittings to rust and degrade.
They are safe to use but for peace of mind I would like to replace them.
PostPosted: Mon Jun 17, 2013 3:56 pm Up
Visit the dealer and let them tell you which bits are needed.
PostPosted: Mon Jun 17, 2013 4:07 pm Up
Not too sure which ones you mean. If you want genuine just get the part numbers off service box. (I don't trust the dealer to order the right ones)
Definitely don't just go throwing random bolts in because they appear the correct diameter and length. Far more unsafe then the worn ones already on it.
QuArTz
PostPosted: Mon Jun 17, 2013 4:11 pm Up
Trade Rating: +16
I wasn't goint to get any old nut and bolts, I want to put ones which are like for like..
