Online Now [131]:
Visitors: 131
Today: 29604
Total: 143338575
Forums › The Car › 206 Problems › Don't try this on your car
Majid
PostPosted: Tue Jun 18, 2013 4:08 am Up
Hi I cleaned my 206 1.6 16v 2003
Throttle body by removing and disconnecting the Throttle Position Sensor
Cleaned it all and attached to the car.
Started the car and engine management light come on
I forgot to connect TPS wire.
connected it again and started it lights still on.
Any ideas of getting rid of this light?
Thank you guys
PostPosted: Tue Jun 18, 2013 4:51 am Up
Keep going and hope it goes away.
Otherwise it will need clearing with diagnostic equipment.
Anyway that's nothing, you should see what I do to mine..
Majid
PostPosted: Tue Jun 18, 2013 11:47 am Up
But the car keeps idling up and down irratically
Peugeot 206, 1.6, 16 valve
2003
Mr-Tigger
PostPosted: Tue Jun 18, 2013 11:54 am Up
bsi reset procedure....though tbh if the part is in there it shouldnt hunt unless there's actually a problem
Majid
PostPosted: Wed Jun 19, 2013 4:19 am Up
Bsi reset worked thanks
2003
