Latest: cogeim7
Overall: 17185
Online Now [760]:
Visitors: 759
Today: 186537
Total: 147084884
Forums › The Car › 206 Problems › Instrument Lighting not working
DeepBlue
PostPosted: Tue Jun 18, 2013 12:35 pm Up
Hi, I've got a problem on my X reg 206 with the instrument cluster lighting. The lights behind the dials don't come on as they should when you turn on the side/head lights, not helpful when driving at night! All the other lights on the dash are working.
Took the problem to a garage, they advised me to go away and get a replacement cluster with a lower mileage which I did...same problem. Also the mileage didn't go up to the actual mileage of the car as its supposed to when I swapped the new cluster in. My one has the two connectors on the back (white and yellow).
I've checked the bulbs and the fuses, cleaned up the earth strap from battery to gearbox and checked the wire that is for the instrument lighting according to Haynes (grey one on the white connector). Can't see anything wrong with the connection on that particular pin, however there is a buzzing noise every time I connect the white connector on the cluster (with the battery still connected).
No other electrical problems on the car, am at a bit of a loss here so any advice would be greatly appreciated! Thanks.
PostPosted: Tue Jun 18, 2013 12:38 pm Up
Have you tried removing the dash illumination dimming wheel & bypassing it?
Sometimes the resistor inside the dimmer fails.
gazza82
PostPosted: Wed Jun 19, 2013 3:16 am Up
The mileage is stored on the cluster .. it won't increase to match what is stored on the BSI unit ... who ever told you that is talking out of their ar$e ... so I'd avoid going to that particular garage again ... Wink
DeepBlue
PostPosted: Thu Jun 20, 2013 12:54 pm Up
Thanks, that was exactly the problem! Don't think I've ever used the dimmer while owning the pug, didn't realise what it's connected to. Decided to get a replacement switch ordered.
The garage I used claim to be experts on French cars...hmmmm... Rolling Eyes
