Latest: S2cgm
Overall: 17178
Online Now [108]:
Visitors: 107
Today: 17518
Total: 137084693
Forums › The Car › 206 Problems › Cold start issues
Cold start issues
LiamGTi180
PostPosted: Sat Jun 22, 2013 6:43 am Up
Right I've been putting up with this problem for a while but now it's got a lot worse. It doesn't like cold starts. When I pull away it really struggles and when I push the accelerator slightly the revs drop. Now it's banging and sounds like a misfire. When the cars warm it runs normally with no issues.
Any ideas? I thought coil pack maybe
PostPosted: Sun Jun 23, 2013 1:19 pm Up
I believe that the GTI like most has two temp sensors. One is for the gauge and one is for temp to ECU to ensure correct fuelling. If the sensor is defective it might be sending a signal to the ECU saying the engine is already hot so for a cold engine it would under fuel the car and run lean when cold so it could be that sensor.
Personally though I am with you and would suspect coil pack. Can you swap with a mate?
broadblaster
PostPosted: Sun Jun 23, 2013 2:04 pm Up
personally i would be looking at the temp sensor first before spending out on a new coil pack.
both of my 180's used to run rough from cold but changed the sensors and it has made a big diffrence to them.
on a back road playing
PostPosted: Sun Jun 23, 2013 2:20 pm Up
This is absolutely correct. Thermistors in temp sensors 'wear-out' by changing slightly in resistance from repeated cold-hot cycles.
Check for yourself by comparing Ω of a brand new one to an aged used one.
