Latest: tbafonso
Overall: 17130
Online Now [112]:
Visitors: 111
Today: 12175
Total: 103747995
Forums › The Car › 206 Problems › engine conversion help?
tbagL7
PostPosted: Sat Jun 29, 2013 6:57 am Up
my engine has blown in my 206 XSI 1.6 and want to stick a GTI 2.0l engine isn't it would it fit in or not please help guys??
TRobbins
PostPosted: Sat Jun 29, 2013 7:35 am Up
This is the most common question asked on this forum.
Of course it will fit, it's still a 206 after all. You just need engine, gearbox, subframe, gear linkage, hubs, drive shafts, exhaust, PAS pipes...ECU...all the wiring...
PostPosted: Sat Jun 29, 2013 2:43 pm Up
I agree! What He Said
tbagL7
PostPosted: Sat Jun 29, 2013 3:35 pm Up
i just wanted to make sure thats all guys cheers anyways
TRobbins
eddie206
PostPosted: Sat Jun 29, 2013 4:31 pm Up
The real answer is yes it fits but why struggle with doing it and affording it when you may as well just buy a gti...and dont think you can avoid the insurance prices because as soon as u get a problem u will be discovered and in deep doodie then..
tbagL7
PostPosted: Sat Jun 29, 2013 5:07 pm Up
cuz my xsi is custom st orange paint job and modified to f*** so i just want the engine instead of a whole new car lol
TRobbins
PostPosted: Sun Jun 30, 2013 3:56 am Up
See Edwards reply, it isn't just the engine........
PostPosted: Sun Jun 30, 2013 4:40 am Up
'modified to f***' Laughing
In all honesty it really isn't worth it for the small bhp increase. A decent setup cammed XSI will see the same power anyway and be a hell of a lot easier.
PostPosted: Sun Jun 30, 2013 4:52 am Up
But the 1.6 will never compete on torque though.
Tolkienfan001
PostPosted: Sun Jun 30, 2013 4:57 am Up
Trade Rating: +13
Is there any reason you can't just rebuild the engine? would this not be a better option?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sun Jun 30, 2013 5:19 am Up
Unless the GTI is going to be modified, I still don't think it's worth the hassle.
PostPosted: Sun Jun 30, 2013 5:29 am Up
It wasn't worth doing engine conversions on 206's 5 years ago, nothing's changed.
PostPosted: Sun Jun 30, 2013 6:34 am Up
A 180 conversion on a 206 SW Si could be nice.
eddie206
PostPosted: Sun Jun 30, 2013 6:41 am Up
Hey Edward what improvements in the numbers are you gettin with your uprated 138??and for the engine bay extras including all the engine improvements how much would you say its cost without the susspension and things away from the engine bay???would appreciate a ball park figure to improve my 138???
Thanks man..
PostPosted: Sun Jun 30, 2013 10:37 am Up
There's about £8k gone into that engine...that won't include all the little bits like nuts and bolts and all the little bits which cost a fair bit.
Exhaust £1,300
VB mounts £200
Cylinder head would be about £800 new
New Peugeot hydraulic lifters £350
TB's, Omex ECU, cams, verniers, injectors, mapping, oil, gaskets, coolant etc £4,000
Inlet manifold £100
ITG air filter and baseplate £150
90mm air horns £140
Thermostat housing £100
Auto electrician and wiring components £450
Radtec radiator and fan £500
Samco hoses £70
elec power steering pump £35
PAS pump bracket £15
PAS piping £50
