Online Now [314]:
Visitors: 313
Today: 42168
Total: 106087998
Forums › The Car › 206 Talk › Removing Air Con Etc
Zack
PostPosted: Mon Jul 01, 2013 1:12 pm Up
Im removing my air con and changing my power steering to electric pump.
What belt to use now tho?
cheers
PostPosted: Mon Jul 01, 2013 1:20 pm Up
Where you going to fit the pump? 6PK820 is the belt you need.
Zack
PostPosted: Mon Jul 01, 2013 1:21 pm Up
Thank you Smile im going to run a Saxo pump not sure where tho any ideas?
Smile
Zack
PostPosted: Mon Jul 01, 2013 1:31 pm Up
Where can i get a 6PK820
Smile thanks
PostPosted: Mon Jul 01, 2013 2:52 pm Up
Euro Car Parts. If you've still got the original airbox it won't fit. It might even get in the way of the standard radiator etc.
usher
PostPosted: Mon Jul 01, 2013 3:00 pm Up
Haynes manual might help
I'll be doing it when I have the matrix out and seats in which will be a while as yet since I don't have the seats lol
Thread jack but which belt for just air con removal
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Mon Jul 01, 2013 3:02 pm Up
I'll be doing it when I have the matrix out and seats in which will be a while as yet since I do think have the seats lol
project thread WIP
garage
FAQ
206 gti firedance
Zack
PostPosted: Mon Jul 01, 2013 3:33 pm Up
Any chance of a picture with it fitted?
Cheers
Zack
PostPosted: Wed Jul 03, 2013 9:38 am Up
Got a saxo pump £25.00 woop picking belt up tomorrow euro car parts what fuse should i run on pump?
Cheers
PostPosted: Wed Jul 03, 2013 12:28 pm Up
You got the bracket too? I think it's a 40 amp for the fuse. You can use the spare slot in the fuse box like I've done.
Zack
PostPosted: Wed Jul 03, 2013 12:49 pm Up
Ok thanks for your help what bracket one off the saxo?
Cheers
PostPosted: Wed Jul 03, 2013 2:11 pm Up
Yep...
Zack
PostPosted: Wed Jul 03, 2013 2:30 pm Up
Edward wrote:
Yep...
Ill get one to moz what piping did you use for the pump?
Cheers
PostPosted: Wed Jul 03, 2013 3:09 pm Up
Zack
PostPosted: Wed Jul 03, 2013 3:12 pm Up
Edward wrote:
Wow so clean and good!!
