Latest: tebas93089
Overall: 17179
Online Now [131]:
Visitors: 131
Today: 39071
Total: 138457583
Forums › The Car › 206 Problems › airbag light on
airbag light on
captaincaveman
PostPosted: Tue Jul 02, 2013 12:39 pm Up
Hi all, just got my lad a 04 plate 206 1.1. The airbag light is staying on the dash, apparently it had a new battery not long ago. Having read a bit about this there seems to be various issues but were do i start. Could the battery swap have caused this? Apparently it didnt do it before. is there a way i can disconnect battery and then re connect it to possibly 'reboot it'. How can i find out fault codes without going to dealer? Thanks
PostPosted: Tue Jul 02, 2013 12:51 pm Up
Seeing as you have just got the car, have you checked the passenger airbag disarm switch on the dash hasn't been set to OFF?
If the switch is OFF the passenger airbag warning lamp will stay on all the time.
Peugeot Planet really needed to scan for airbag fault codes, stick up what area of the UK you are in as many forum members have the kit to scan 206's.
captaincaveman
PostPosted: Tue Jul 02, 2013 1:02 pm Up
Hi, have tried the passenger airbag switch and when it is switched to off it brings up another light, so I assuming that is ok. Live near Coventry, I take it Peugeot planet is a plug in diagnostic tool.
PostPosted: Tue Jul 02, 2013 1:04 pm Up
captaincaveman wrote:
I take it planet Peugeot is a plug in diagnostic tool.
PSA diagnostic software runs of a laptop with a special interface.
Reboot BSI unit first then, follow the link as instructions are listed here>
www.206info.co.uk/Foru...=1675.html
captaincaveman
PostPosted: Tue Jul 02, 2013 1:40 pm Up
nice one, i will try the bsi reboot first, thanks
PostPosted: Tue Jul 02, 2013 2:01 pm Up
I thought there was only one airbag light? If thats the case are you sure the original light thats staying on is the airbag light?
PostPosted: Tue Jul 02, 2013 2:11 pm Up
Nope, there is at least 2 on a multiplexed 206.
PostPosted: Tue Jul 02, 2013 2:16 pm Up
Fair enough, never noticed, never had reason to turn the passenger bag off & the only time my airbag light comes on is during self check before starting the car.
captaincaveman
PostPosted: Tue Jul 09, 2013 12:16 am Up
Hi, tried the dsi reboot but couldn't get the bong noise when lights turned. Tried a few times but couldnt get noise and light still on so gonna take it in for diagnostics.
pug206lx
PostPosted: Tue Jul 09, 2013 4:37 pm Up
Check the wires under the seats are still attached.
captaincaveman
PostPosted: Tue Jul 09, 2013 11:23 pm Up
Did look there but no cables or connectors under seats.
PugJH
PostPosted: Wed Jul 10, 2013 12:52 am Up
Give us a bit more info.
What model is it? Did you have a HPI check done
As above where do you live, someone local could check codes for you
WIP: Black 1.6 16v XSi
Beauté Noire
captaincaveman
PostPosted: Wed Jul 10, 2013 2:54 am Up
Model 206 1.1 s 2004 plate. Live near Coventry.
