Forums › The Car › 206 Talk › Removing Air Con Etc |
Posted: Mon Jul 01, 2013 1:12 pm |
Im removing my air con and changing my power steering to electric pump.
What belt to use now tho?
cheers
Posted: Mon Jul 01, 2013 1:20 pm |
Where you going to fit the pump? 6PK820 is the belt you need.
Posted: Mon Jul 01, 2013 1:21 pm |
Thank you im going to run a Saxo pump not sure where tho any ideas?
Posted: Mon Jul 01, 2013 1:31 pm |
Edward wrote: |
Where you going to fit the pump? 6PK820 is the belt you need. |
Where can i get a 6PK820
thanks
Posted: Mon Jul 01, 2013 2:52 pm |
Euro Car Parts. If you've still got the original airbox it won't fit. It might even get in the way of the standard radiator etc.
Posted: Mon Jul 01, 2013 3:00 pm |
Haynes manual might help
I'll be doing it when I have the matrix out and seats in which will be a while as yet since I don't have the seats lol
Thread jack but which belt for just air con removal
Posted: Mon Jul 01, 2013 3:02 pm |
I'll be doing it when I have the matrix out and seats in which will be a while as yet since I do think have the seats lol
Posted: Mon Jul 01, 2013 3:33 pm |
Edward wrote: |
Euro Car Parts. If you've still got the original airbox it won't fit. It might even get in the way of the standard radiator etc. |
Any chance of a picture with it fitted?
Cheers
Posted: Wed Jul 03, 2013 9:38 am |
Got a saxo pump £25.00 woop picking belt up tomorrow euro car parts what fuse should i run on pump?
Cheers
Posted: Wed Jul 03, 2013 12:28 pm |
You got the bracket too? I think it's a 40 amp for the fuse. You can use the spare slot in the fuse box like I've done.
Posted: Wed Jul 03, 2013 12:49 pm |
Edward wrote: |
You got the bracket too? I think it's a 40 amp for the fuse. You can use the spare slot in the fuse box like I've done. |
Ok thanks for your help what bracket one off the saxo?
Cheers
Posted: Wed Jul 03, 2013 2:11 pm |
Yep...
Posted: Wed Jul 03, 2013 2:30 pm |
Ill get one to moz what piping did you use for the pump?
Cheers
Posted: Wed Jul 03, 2013 3:09 pm |
Posted: Wed Jul 03, 2013 3:12 pm |
Edward wrote: |
Wow so clean and good!!
