Online Now [460]:
Visitors: 459
Today: 129854
Total: 106467034
Forums › The Car › 206 Talk › Size Wire For Battery to boot
Zack
PostPosted: Wed Jul 03, 2013 3:09 pm Up
What wire to use to put battery in boot also where from?
Cheers
did a search couldnt find anything
PostPosted: Wed Jul 03, 2013 3:10 pm Up
Why do you need to move it to the boot?
Zack
PostPosted: Wed Jul 03, 2013 3:13 pm Up
Make room for the pump yours has been done like well good!!
PostPosted: Wed Jul 03, 2013 4:41 pm Up
What pump?
eddie206
PostPosted: Wed Jul 03, 2013 5:24 pm Up
I dare say the cable from a good long set of jump leads will be sufficient with an in line fuse spliced onto the live tho...BUT...
IF you are buying a suitable battery box to contain the battery from fumes and from smoking the place you get that from will sell the ideal wiring/cabling and should assist with any advice...
Best place to buy these things is your nearest good motorsport/tuning seller..or see fast car mag or similar or even interweb under uk motorsport retailer or sumthing.
PostPosted: Thu Jul 04, 2013 11:54 am Up
Don't.
Zack
PostPosted: Thu Jul 04, 2013 12:02 pm Up
Not going to now Smile
PostPosted: Thu Jul 04, 2013 12:06 pm Up
Good.
