Latest: Kifi69
Overall: 17183
Online Now [398]:
Visitors: 397
Today: 129799
Total: 143789907
Forums › The Car › 206 Problems › 1.6 HDI Hiccup then stopped and wont start.
nellyhaggis
PostPosted: Wed Jul 03, 2013 4:09 pm Up
as the title says ive been driving my 206 hdi 1.6 and the car has hiccup at a corner then half a mile down the road it lost all power and stopped and wouldnt start again.
The history behind it is there has been a strange lack of power when I put my foot down sometimes then it would clear and go like stink. Its been doing it for ages the a speed sensor fault came up so i replaced it. All seemed well after i changed it but then it started doing it again and then it died as mentioned above.
Any pointers or areas to look at would be great as ive come up blank with it.
I have ran a diagnostic on the car and it has no faults'
Basically im at the point where i will have to take it to pug which is a very last resort.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
eddie206
PostPosted: Wed Jul 03, 2013 5:36 pm Up
Does this have a turbo??
PostPosted: Thu Jul 04, 2013 11:26 am Up
You need to go back to basics, diagnostics machines cant pinpoint all faults.
All PSA HDI engines have at least one turbocharger.
eddie206
PostPosted: Fri Jul 05, 2013 4:25 am Up
Well i dont have much expe. with diesels but have you noticed it smoking more than usual?
Possible faulty speed sensor?
Fuel pump?
Im sure someone can offer some better advice...they usualy do..!
Serves as a bump if nothing else..
I ask about the smoke with reference to the turbo and symptoms given..?
nellyhaggis
PostPosted: Mon Jul 08, 2013 2:03 am Up
No smoke. It just throws fresh air out the exhaust.
I changed the fuel filter and I thought that was the end of it then it.
It ran faultlessly for 250 miles then I jump in it this morning and the sod won't start.
I also changed the speed sensor.
One thing thou, should the rev counter register when I turn it over?
Just thinking it might be the crank sensor.
nellyhaggis
PostPosted: Wed Jul 17, 2013 3:21 pm Up
Fuel rail pressure sensor. Done.
