Posted: Wed Jul 03, 2013 3:09 pm |
What wire to use to put battery in boot also where from?
Cheers
did a search couldnt find anything
Posted: Wed Jul 03, 2013 3:10 pm |
Why do you need to move it to the boot?
Posted: Wed Jul 03, 2013 3:13 pm |
Make room for the pump yours has been done like well good!!
Posted: Wed Jul 03, 2013 4:41 pm |
Zack wrote: |
Make room for the pump yours has been done like well good!! |
What pump?
Posted: Wed Jul 03, 2013 5:24 pm |
I dare say the cable from a good long set of jump leads will be sufficient with an in line fuse spliced onto the live tho...BUT...
IF you are buying a suitable battery box to contain the battery from fumes and from smoking the place you get that from will sell the ideal wiring/cabling and should assist with any advice...
Best place to buy these things is your nearest good motorsport/tuning seller..or see fast car mag or similar or even interweb under uk motorsport retailer or sumthing.
Posted: Thu Jul 04, 2013 11:54 am |
Don't.
Posted: Thu Jul 04, 2013 12:02 pm |
Not going to now
Posted: Thu Jul 04, 2013 12:06 pm |
Good.
