Online Now [377]:
Visitors: 376
Today: 26406
Total: 142294912
Forums › The Car › 206 Problems › BSI, ECU, READER & chip replacement
LORDPSK
PostPosted: Thu Jul 04, 2013 6:42 pm Up
I was recently having problems with a 2000 1.9 diesel (non turbo) 206, after discussion on here I decided to get a like for like swop, so I got the chip, ecu, bsi and the reader from a donor car, put it onto my car and all the electrics work including the remote central locking but the car fails to start. The EML light is on steady, car cranks over but no joy, I have tried rebooting the bsi using every technique listed on google and here, any suggestions were I am going wrong would be greatfully received
Steve
Peugeot 206
PostPosted: Fri Jul 05, 2013 12:37 am Up
Scan the codes with Peugeot Planet 2000 diagnostics and all will be revealed.
PostPosted: Fri Jul 05, 2013 2:53 am Up
Diagnostic light will stay on all the time until the engine is up & RUNNING.
LORDPSK
PostPosted: Fri Jul 05, 2013 3:46 am Up
Hi have scanned with pp but no codes shown up, I though the EML light would flash if non compatible
Peugeot 206
PostPosted: Fri Jul 05, 2013 11:15 am Up
Ah yes.
OK, have you checked status of immobilistation?
It must say ECU unlocked up the top otherwise it won't start.
Check in BSI parameter reading and also make sure the ECU configs are correct for the specific vehicle fitted.
PostPosted: Fri Jul 05, 2013 11:48 am Up
Mate there is no ecu or if there is (cant quite remember) its retardedly basic. All you have a is a coded stop start solenoid on the pump. Replace it with a single wire one from euro car parts (15 or so quid) and it will start.
You loose your immobiliser though. And have a choice of removing the pump or cutting a hole in the cover.
Can I ask why did you change all that?! Ie was it an engine swap or something
LORDPSK
PostPosted: Mon Jul 08, 2013 3:19 am Up
The indicators and wipers stopped working, which points towards the BSI being faulty, or could you suggest a different solution
Peugeot 206
LORDPSK
PostPosted: Tue Jul 16, 2013 8:49 am Up
Right decided to change the solenoid, but how does it come out without removing the pump, seems to have snap off head security screws in it.
thanks
steve
Peugeot 206
