Latest: tebas93089
Overall: 17179
Online Now [110]:
Visitors: 109
Today: 37368
Total: 138184223
Forums › The Car › 206 Problems › Air con Evaporator - Does the dash 'really' have to come out
crocdino
PostPosted: Tue Jul 02, 2013 9:34 am Up
As above really... Loud hissing etc from behind the dash.. A specialist has diagnosed it over email as either the evaporator or something gone on a union/join.
He spoke like it would be an issue to remove the evaporator and a quick google suggests so! With the whole dash coming out - if this is the case I'd just not bother.. I saw a how-to with the heater matrix coming out ok, can I do the same with the evaporator?
Cheers!
GTI 138 facelift - Runabout
335d M Sport - Cruiser
Hawkers
PostPosted: Tue Jul 02, 2013 10:31 am Up
How loud is it? Because my aircon hisses when it's on, but that's how it operates.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
crocdino
PostPosted: Tue Jul 02, 2013 11:06 am Up
It happened last summer. It worked perfectly with no hiss.
Then over the space of 30 mins there was a very loud hiss, then it stunk, then AC didn't work!
ukskater01
PostPosted: Tue Jul 02, 2013 1:35 pm Up
Defiantly got a leak, would be easier to Pressure test the system with an air-con machine. Check the pipes going to the heater matrix, check the condenser hasn't got any holes in it and that the high and low filling pipes are ok. I haven't got air-con on mine so can't go into more detail
PostPosted: Tue Jul 02, 2013 1:38 pm Up
If the system has a leak it needs to be either pressure tested with Nitrogen OR a vac check done.
PostPosted: Tue Jul 02, 2013 5:04 pm Up
I think Qwikfit might do a no fix no fee that starts with vacuum test but it sounds like that will only prove what you already know.
crocdino
PostPosted: Mon Jul 08, 2013 12:41 pm Up
Cheers lads.. This is what I'm going to get done.
I was just curious if the leak is in the evaporator is there any way of getting it out without removing the dash?
PugJH
PostPosted: Mon Jul 08, 2013 3:20 pm Up
Maybe this is the same as I fixed on my gf's glx (climate control)
It used to hiss when ac was on, like a bubbling, up and down in pitch etc. then the resistor in the blower motor went and it was stuck on high fan
New blower motor resolved the problem.
Unplug this 1st, see if it still makes the noise, if it does then its further back from the cab, I would think anyway.
Mine was easier to pin point once the resistor failed
WIP: Black 1.6 16v XSi
Beauté Noire
pug206lx
PostPosted: Mon Jul 08, 2013 4:40 pm Up
Mine also always hisses quite loudly every now and then
crocdino
PostPosted: Sun Jul 14, 2013 12:39 pm Up
Sorry.. The AC worked fantastic. It was a real loud hiss over half hour or so, stunk, then hasn't worked since.
It's deffo something that's let go. I'll see what the specialist says!
