Latest: tebas93089
Overall: 17179
Online Now [307]:
Visitors: 306
Today: 17965
Total: 138211669
Forums › The Car › 206 Problems › 206 GTi EGR Valve?
206 GTi EGR Valve?
206gt160
PostPosted: Wed Jul 10, 2013 9:01 am Up
Does the 206 GTi have an EGR valve and if so are they as prone to clogging as Diesel EGR valves?
Also where is it situated if it has one.. a pic would be very handy]
PostPosted: Wed Jul 10, 2013 1:17 pm Up
Yes they do have one,but it don't clog as much as the Diesel engines do,because the petrol engine is much cleaner one,but it can be cleaned as a last try before replacing it,it's usually located on the top of the engine,on the passenger side,close to the inlet,will try to find a pic for you
206gt160
PostPosted: Wed Jul 10, 2013 3:38 pm Up
Thanks for the reply I'll have a look see if I can find it.. Ive taken my 2.0 tdi 170 egr off before was going to block it but cleaned it and got a great result. Might just block it off on the 206.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Wed Jul 10, 2013 3:59 pm Up
You can remove it and add the plate from the GTi 180 but the ECU light will come on.
206gt160
PostPosted: Wed Jul 10, 2013 4:17 pm Up
I'm going to make up a plate for it this week.. Should improve mileage slightly and lower the intake temps which is always good as well.
mattymj
PostPosted: Wed Jul 10, 2013 4:42 pm Up
Does the gti 180 have one? Mines idling rough at the moment. Wandering revs at Tickover etc
PostPosted: Thu Jul 11, 2013 1:52 am Up
Don't think the 180 does at all. I wouldn't bother removing it. Doesn't do much anyway.
206gt160
PostPosted: Thu Jul 11, 2013 2:42 am Up
I'll find where mine is tonight post a pic and you can see if yours has one or not by comparing..
it Lowers the intake temperature and the engine will run cleaner and also help the longevity of the engine and should get a couple more mpg.
Your not throwing the dirty used gases back through your engine.
PostPosted: Thu Jul 11, 2013 6:30 am Up
and your ECU light will be on!
206gt160
PostPosted: Thu Jul 11, 2013 7:06 am Up
I know you said that further up the post, You can get them mapped out on my Audi for the egr and dpf (not a good idea with MOT soon) so sure enough you should be able to do the same with this.
Cars due for a Remap so I would get them to do it then.
