Online Now [142]:
Visitors: 141
Today: 14975
Total: 106144678
Forums › The Car › 206 Problems › Not picking up fuel
Not picking up fuel
deaconPug
PostPosted: Wed Jul 10, 2013 12:15 pm Up
My fuel pump died about 2 weeks ago so i fitted a new fuel pump, it worked. i left it for a week when on holidays, came back and it wouldnt start. i changed the fuel pump again as it was under warrenty, didnt work, changed the battery, tested the wires going into the fuel pump and fuses and still no luck. The car is also telling me it is in "Eco mode" even though the battery is fully charged if that helps.
PostPosted: Wed Jul 10, 2013 12:22 pm Up
ECO MODE will go once the engine is running, its just a battery saving function.
You need to tell us what engine your 206 has so we know what fuel system we are dealing with, all we do know is its multiplexed.
deaconPug
PostPosted: Wed Jul 10, 2013 12:41 pm Up
1.4 petrol its an october 2002 lx model
deaconPug
PostPosted: Wed Jul 10, 2013 12:45 pm Up
Eco mode normally only activates when the battery is low or if an electrcal component has been removed doesnt it? it comes on when i change a bulb etc.. :s
PostPosted: Wed Jul 10, 2013 12:54 pm Up
ECO MODE comes on after a set time when the engine is stopped if the car hasn't been locked to protect the battery from being drained.
deaconPug
PostPosted: Wed Jul 10, 2013 12:57 pm Up
That makes more sense. any ideas as to the problem? i was thinking maybe a blocked fuel line? how would i check this?
PostPosted: Wed Jul 10, 2013 1:24 pm Up
does the engine stall?please tell us more about your problem
deaconPug
PostPosted: Wed Jul 10, 2013 1:31 pm Up
doesn't stall it 100percent wont start. when i turn the key it tries to start just sounds dry and horrible. vive disconnected the fuel line from the fuel pump and no fuel squirts out which is what causes me to think its not picking up fuel.. what other details do you require?
PostPosted: Wed Jul 10, 2013 1:38 pm Up
Does the immobiliser shut off the fuel pump on a multiplexed?
It would make sense and then no un-burnt fuel is contaminating the cat.
deaconPug
PostPosted: Wed Jul 10, 2013 1:47 pm Up
how do i tell if the immobiliser shuts it off?
macj
PostPosted: Wed Jul 10, 2013 2:12 pm Up
is there power to the pump?..... if not check fuel pump relay
deaconPug
PostPosted: Wed Jul 10, 2013 2:17 pm Up
yeah there is power, i have put a voltage tester to the wires and 3 of 5 are live, 2 are earths
PostPosted: Wed Jul 10, 2013 3:26 pm Up
Can you hear the pump priming?
deaconPug
PostPosted: Wed Jul 10, 2013 3:29 pm Up
Nope, nothing at all
PostPosted: Wed Jul 10, 2013 3:32 pm Up
Check the fuel pump fuse then, or it could be the fuel pump relay.
