Online Now [1064]:
Visitors: 1063
Today: 186516
Total: 148944538
Forums › The Car › 206 Problems › 2 problems :(
2 problems :(
Go to page Previous  1, 2
eddie206
PostPosted: Wed Jul 03, 2013 5:02 pm Up
I think it will vary depending how you look and what you wear and say...for instance if you turn up in overalls that are used you will likely get a better price than if you had turned up in a suit and tie talking on your mobile and looking flash..
The overalls can qualify you for trade price parts often aswell..especialy if there's a trade logo on them...but im not suggesting charging some companys account..thats bad news..
adamb
PostPosted: Wed Jul 10, 2013 12:21 pm Up
Right little update and hope to pick some brains Smile
Eml has been turned off by resetting I bought a new cat pipe and cat and swapped it. Fixed all good.
However for the abs fault it threw up a code 0120 any thoughts on this? It just said unknown on his machine. But then said the wheel speed was reading 9km/h on the rear and 0 on the front(car was stationary Lol) Also said something about track 2 I think
Thinking back the abs light came on after the battery had run down and the recovery used a jump starter pack and then the light came on.
Any help is much appreciated ")
1999 206 1.6 Roland garros gone
02 2.0 d-turbo with tuning box Smile
PostPosted: Wed Jul 10, 2013 12:24 pm Up
A very good way to potentially fry the BSI unit & do all sorts of damage to the digital electrical system.
adamb
PostPosted: Wed Jul 10, 2013 12:27 pm Up
I know but how else are you meant to start it? I'm the middle of a field lol
Ignorance 1. What's the bsi? ")
PostPosted: Wed Jul 10, 2013 12:32 pm Up
The cars software driven computer brain that controls ALL the cars electrical systems over the digital CAN VAN network.
More info here: www.206info.co.uk/Foru...=1675.html
adamb
PostPosted: Wed Jul 10, 2013 3:01 pm Up
Thanks for the info.
Does anyone know anymore about the code 0120? For the abs?
Could it be a bad connection or a broken cable? Not sure why its reading 9km/h at stationary tho?
Hawkers
PostPosted: Wed Jul 10, 2013 3:07 pm Up
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
adamb
PostPosted: Wed Jul 10, 2013 4:19 pm Up
I found this but why would it be saying the rear wheel speed of 9km/h?
But if it is that how do I fix it. He got all the data up and then pressed the pedal but the diagnostics was saying the pedal was not being pressed. Is there just a simple screw in sensor on top or is somewhere else?
Edit* also why would it be the throttle position sensor for the brake pedal?
Page 2 of 2
