Latest: lio94
Overall: 17181
Online Now [195]:
Visitors: 194
Today: 55140
Total: 141694807
Forums › The Car › 206 Problems › fuel rail/ injector leaks
FezzaCM
PostPosted: Wed Jul 17, 2013 4:06 am Up
right, the 206 had a misfire, so i found out it was highly possible that injector 3 was the problem... so after purchasing an injector i took all the fuel rail off, replaced the injector, fitted it all back together...
now have the issue.. the fuel leaks out from every injector (fuel rail end)
any ideas guys?
The Cars, The People, The Scene
Cruise-Mids.com
PostPosted: Wed Jul 17, 2013 4:31 am Up
Sounds like either you haven't put the injectors back in properly or the O rings have knackered and need replacing.
FezzaCM
PostPosted: Wed Jul 17, 2013 6:01 am Up
just found out the 0 rings wernt on.. found them all on the floor lol
thing is.. how the hell do you push the rail back onto the injectors now the 0 rings are on? seems like it dont fit
Cruise-Mids.com
PostPosted: Wed Jul 17, 2013 7:30 am Up
A bit of Vaseline and a bit of force. They are designed to be a tight fit. Once you figure out the twist and rotation and angles for the first one to go in, the others will be easy
