Latest: Kifi69
Overall: 17183
Online Now [420]:
Visitors: 419
Today: 118581
Total: 144136418
Forums › The Car › 206 Problems › Idle Control Valve
Idle Control Valve
pugot206
PostPosted: Sat Jul 20, 2013 8:51 am Up
Hi can anyone let me know precisely where the ICV is located, have searched the forums and its near the Throttle body but still cannot see it
Sorry i need a idiots guide as a newbie pug fixer.
Tia.
PostPosted: Sat Jul 20, 2013 9:04 am Up
All depends what car it's on!
pugot206
PostPosted: Sat Jul 20, 2013 9:15 am Up
Its a 1.4 8v 2006 206
PostPosted: Sat Jul 20, 2013 12:38 pm Up
Well here is a pic of it,it's the one on the right next to the screw that i was taking off
and it's the one I'm holding with my fingers here:
and take a look at this guide it might help you:
Cleaning Throttle Body
pugot206
PostPosted: Sat Jul 20, 2013 7:51 pm Up
Timon thanks very much, will have a dismantle when daughter stops drving it.
PostPosted: Sun Jul 21, 2013 1:19 am Up
You are most welcome :),keep us updated Smile
pugot206
PostPosted: Wed Jul 31, 2013 5:41 am Up
Have just done ICV cleaned out with carb spray idles alot smoother one of the easier jobs
Thanks TIMON for making it easy.
Just got to have a look at the mot advisory-steering rack movement on driverside- sounds like big job and expensive.
pugot206
PostPosted: Thu Aug 01, 2013 4:05 am Up
Started engine this morning still has idle splutter, give accelerator a tap and idles cold start properly will have to dismantle the throttle body as it has similar one to the GTI and doesn't appear to have the seperate idle control valve.
I have throttle similar to this-
www.ebay.co.uk/itm/171..._45wt_1172
PostPosted: Sat Aug 03, 2013 3:57 am Up
The pictures Timon supplied are correct for the 1.4 8V. In your previous post you said that you had cleaned the ICV. Now you are saying that you don't have one. Is this another car to your previous post?
pugot206
PostPosted: Sat Aug 03, 2013 7:09 am Up
I have cleaned the throttle body as i realised its not the same as what Timons picture is and posted a link similar to what is on my 1.4, i have used the wrong name of ICV as i have never done one before.sorry for the confusion but looking for any input to sort out the struggling idle problem.
206 1.4 (2CKFWA) 2006 Verve
PostPosted: Sat Aug 03, 2013 7:42 am Up
Yours is the electronic fly by wire type throttle, there is NO mechanical linkage between the throttle pedal & the throttle butterfly, it's all done electronically.
As an added bonus of this fancy modern electronic technology you also pay more road tax then the older mechanical throttle 206 TU engine's that are also taxed on exhaust emissions Laughing
pugot206
PostPosted: Sat Aug 03, 2013 7:50 am Up
Thanks for the reply, so the electronics are buggered or can they be reset, looking expensive.
Just found throttle matching mine
www.ebay.co.uk/itm/251..._206wt_934
PostPosted: Sat Aug 03, 2013 11:31 am Up
Really?
It's the opposite over here because supposedly the ECU stops crap drivers from 'slamming' the throttle..
PostPosted: Sat Aug 03, 2013 11:37 am Up
Really?
Extra £35 a year road tax for the electric fly by wire TU3 compared to my old fashioned throttle cable controlled TU3 Laughing
Fly by wire throttle = 152 g/km CO2 Euro 4 Emissions
Throttle cable = 149 g/km CO2 Euro 3 Emissions
Old fashioned technology just sneaks under the 150 g/km limit for band F tax Cool
pugot206
PostPosted: Sat Aug 03, 2013 7:40 pm Up
Back to the spluttering idle is it due to this electronic throttle or is there another cause before i splash the cash on a electronic throttle.
