Latest: jackrox1992
Overall: 17186
Online Now [449]:
Visitors: 448
Today: 32896
Total: 148202736
Forums › The Car › 206 Problems › 206GTI screeching
206GTI screeching
wezzel98765
PostPosted: Wed Jul 24, 2013 10:21 am Up
Just bought a GTI138
Car engages gear 1 2 and 3 and reverse fine but screeches when engaging into these gears, except third, it won't engage 4 or 5
Big leak of oil on gearbox can be seen so I assume that the gearbox is low on oil
There is a screeching sound when moving in any gear except third gear and sometimes even when the gear stick is not in gear, the car still creeps forward like its in gear
Any ideas please?
Bought this cheap so it's a play toy to fix up and then teach the mrs to drive in it
Smile
wezzel98765
PostPosted: Wed Jul 24, 2013 6:56 pm Up
Changed gear oil!
120ml came out... 2L or so went in...
PERFECT! Smooth as anything ! So so happy!
Smile
DanT
PostPosted: Thu Jul 25, 2013 7:30 am Up
Nice! Could have been a lot worse!
wezzel98765
PostPosted: Thu Jul 25, 2013 7:44 am Up
Gearbox has a small leak , probably why the gearbox had no oil... its in tomorrow with a local mechanic to replace oil seals on the box Smile
Smile
DanT
PostPosted: Thu Jul 25, 2013 7:48 am Up
Probably the driveshaft seals, quite common!
