Online Now [469]:
Visitors: 468
Today: 246818
Total: 146701680
Forums › The Car › 206 Problems › 1.4 hdi fuel filter change help needed
jordaaan22
PostPosted: Thu Jul 25, 2013 12:57 pm Up
is it possible to change just the filter or do I have to change the whole housing? I just bought a filter but cant find a way to open up the housing
TelaKeppi
PostPosted: Thu Jul 25, 2013 2:23 pm Up
I've been offered replacement filters but so far none of housings have been openable. Some cheaper units need the heater from the old unit. I replace the unit once a year.
206 1.4 HDi
jordaaan22
PostPosted: Thu Jul 25, 2013 2:26 pm Up
ok thanks, will try and see if can get one local instead then. I will also change the unit every year if that is what you suggest in doing
DREWDEN
PostPosted: Thu Jul 25, 2013 2:29 pm Up
Just checked Haynes manuel for you, it says on some 1.4hdi models the filter/housing may come as a complete assembly, check with dealer first.
Maybe upload a photo, and someone might know which type you have got.
Or look in service box.
206 2ltr Hdi glx 53 plate
jordaaan22
PostPosted: Thu Jul 25, 2013 2:34 pm Up
thanks DREWDEN, pretty sure mine is a complete assembly. ill take it with me I go to buy a new one and see what the dealer says. cant upload any photos just now currently updating my phone
gazza82
PostPosted: Thu Jul 25, 2013 3:29 pm Up
It's a complete unit on the 1.4 hdi ... the black plastic canister at the back of the right hand end of the engine with several pipes going in and out. About £50-60 I think.
Never changed ours in 10 years! Sad
jordaaan22
PostPosted: Thu Jul 25, 2013 3:52 pm Up
found a few on ebay for roughly £20 but no point buying cheap ones
PostPosted: Fri Jul 26, 2013 2:57 am Up
Well in your car model,you need to change the whole unit,and here is a pic of it,and what do when you get it:
About changing the fuel filter,in your car case,it will be a whole full unit,you take the fuel lines off,by pressing on the lock (colored square),then take the plugs off the (Water Sensor in Gasoil Filter),and (Fuel Reheater),then have the filter out,you need to reuse the water sensor and reheater from the old filter,then fix them tight,and fix the fuel filter back on the bracket,plug the fuel line back,and then before you do anything,you need to make sure that the new fuel filter if full of Diesel,and to do so,you need to squeeze the system with the hand pump,so you prime it,and you need to keep squeezing until the prime hand pump get hard and you will be unable to squeeze it anymore,then start the car,and it will be fine Smile
