Online Now [268]:
Visitors: 266
Bots: 2
Today: 57178
Total: 145362956
Forums › The Car › 206 Problems › 206 Thudding when braking..
NayNay1991x
PostPosted: Fri Jul 26, 2013 1:15 pm Up
Recently been noticing a sound like.. Thud thud thud thud thud when braking, worse when pressed heavily.. Discs and Pads were changed about 5 months ago (Drilled and Grooved discs and Mintex Pads) its definetly not coming from the rear its from the front.
What you guys reckon?
206 1.4i GLX 1999
instagram.com/nay206pug/#
PostPosted: Fri Jul 26, 2013 3:04 pm Up
Does the steering wheel vibrate?
NayNay1991x
PostPosted: Fri Jul 26, 2013 3:38 pm Up
No mate, doesn't pull to any sides either. Although I grabbed the caliper from behind the wheel and could move it and you hear a knocking sound from the caliper should it even make a noise if you move it at all? The bolt that holds the caliper on is tight! Can't tighten it anymore
206 1.4i GLX 1999
PostPosted: Fri Jul 26, 2013 3:42 pm Up
Do all the brakes lock?
You may get a little free play in the caliper when the piston returns slightly, but very little at the least.
Is the caliper carrier bolt loose?
NayNay1991x
PostPosted: Fri Jul 26, 2013 3:49 pm Up
I can literally hold it and shake it and it knocks I have a video but taking ages to go on youtube -.-
206 1.4i GLX 1999
PostPosted: Fri Jul 26, 2013 3:55 pm Up
Somethings loose or the caliper isnt actually working. Check all your work again
NayNay1991x
PostPosted: Fri Jul 26, 2013 3:59 pm Up
youtu.be/xF-rBwVF88E
What you think mate?
Something worth checking out see whats going on?
206 1.4i GLX 1999
PostPosted: Fri Jul 26, 2013 4:06 pm Up
Hmmm still worth a check as that's free but I would be inclined to say its close to normal but maybe a bit too much.
I want to say its down to the discs or hub face but since you dont having any steering wheel vibration under braking it shots that idea down
NayNay1991x
PostPosted: Fri Jul 26, 2013 4:08 pm Up
Would it have any effect that my driveshafts are on there way out as there clicking on full lock. Need to replace them soon.
206 1.4i GLX 1999
PostPosted: Fri Jul 26, 2013 11:13 pm Up
Well you just answered your own question :D,because the Discs are Drilled and Grooved,you will hear that sound Very Happy
PostPosted: Sat Jul 27, 2013 12:17 am Up
I'd check everything is tightned up properly.
NayNay1991x
PostPosted: Sat Jul 27, 2013 1:52 am Up
You don't get a thudding sound from drilled and grooved discs, you get a whirring sound when braking due to air going through.
206 1.4i GLX 1999
billygti137
PostPosted: Sat Jul 27, 2013 8:41 pm Up
Does it still rattle like that if someone presses the brake while you try and shake it like on the film?
Id be stripping them down and if thetes no improvement strip again and check whete your washets are placed then take some extra washers and put them in front of the bolt heads to be sure the bolts arent bottoming and you can get some clamping using the extra6-8mil of washers.....let us know?
