Latest: tbafonso
Overall: 17130
Online Now [222]:
Visitors: 221
Today: 29728
Total: 104384995
Forums › The Car › 206 Problems › play in front hub
play in front hub
steviebee
PostPosted: Mon Aug 05, 2013 1:56 pm Up
Hi, had a drivers side ABS pick up ring brake on my 206 2.0 HDi Sport. So thought I would get the CV joint changed while the fitter was doing this. He changed CV, and now he has loads of play in the hub. He has replaced the wheel bearing and it is still the same. Any ideas, as he is now saying drive flange. What should have been a simple job is turning into a nightmare. He is a good mechanic and has been doing my cars for about 10 years so I trust him.
Steve.
frenchie steve
PostPosted: Mon Aug 05, 2013 3:56 pm Up
Do the driveshaft splines fit correctly into the hub?
steviebee
PostPosted: Mon Aug 05, 2013 4:09 pm Up
Thanks for your reply, I will ask him tomorrow. He thought at first it was the wrong CV. I checked with supplier (J-R from Birmingham) and the old and new CV both have 25 splines, so assume it is ok. he said he put old CV back in hub and it tightened up ok with no play. He replaced bearing and the noise it had was gone, but still loads of play. Wondering if there could be 2 types of CV joint for this for instance perhaps a tapered one? prior to this there was not a problem with it apart from the pick up ring.
Regards.
Steve
frenchie steve
Leegsi
PostPosted: Mon Aug 05, 2013 4:43 pm Up
Did he not put the old and new side by side and see if they were the same?
Also is there a washer before the hub nut goes on and if there is is it sided?
steviebee
PostPosted: Tue Aug 06, 2013 1:25 pm Up
Turns out it was the new CV joint as he first suggested. Seems it was slightly different size than the old original one. Thanks for your replies much appreciated.
Regards
Steve.
frenchie steve
PostPosted: Tue Aug 06, 2013 1:32 pm Up
I would do that and take careful measurements. Something is obviously different. Maybe your car has hubs from a higher performance model (do they vary?) It wouldn't be the first time.
