Online Now [1589]:
Visitors: 1588
Today: 230147
Total: 146128612
Forums › The Car › 206 Problems › Problems on start up.
Dprince90
PostPosted: Tue Aug 06, 2013 8:44 am Up
I have a 206 1.4 16v sport petrol on a 55 plate. I've had it almost 2 years and had no problems but recently on start up from cold it's struggling to run.
When I start the car cold after a few seconds it struggles to maintain revs and jolts badly, almost like a bad misfire. If I apply my foot to the accelerator (in or out of gear) it's revs suddenly drop to almost 400 and near to cut out. If I remove my foot it cuts out totally. But if I keep my foot down all the way after 15/20 seconds it still struggles but the revs then pick up and it runs totally fine from then on.
I have changed all my spark plugs, the coil pack is recently new, I have change the map sensor, coolant temperature control sensor, throttle body and cleaned an ran injector cleaner through it and still no difference. I have plugged my car in to a KTS diagnostics computer and it never reads any errors or faults.
I'm running out of ideas and patients ... Any advice or suggestions from anyone who had experienced this or fixed the issue would be awesome!!!
PostPosted: Tue Aug 06, 2013 9:04 am Up
Cleaned the Idle Control Valve?
HDI90
PostPosted: Tue Aug 06, 2013 9:10 am Up
VVT sensor try cleaning that out
GTI 180
