Posted: Tue Aug 06, 2013 1:46 pm |
| Edward wrote: |
| Brocagh2004 wrote: |
| The odometer is clocking up the miles, the only thing not working is the speedo.......everything else if sound |
That suggests the speedo is at fault then. Otherwise the odometer wouldn't be working either if the problem was elsewhere. |
Will be the classic non plexed speedo dodgy drive motor issue in the instrument cluster.
Posted: Tue Aug 06, 2013 2:04 pm |
| MrBSI wrote: |
| Edward wrote: |
Will be the classic non plexed speedo dodgy drive motor issue in the instrument cluster. |
Thanks for that, so its best to change the whole instrument cluster with another one which has clocked up lower mileage than mine then and job done??
| MrBSI wrote: |
| Edward wrote: |
Thanks for that, so its best to change the whole instrument cluster with another one which has clocked up lower mileage than mine then and job done?? |
It can be any milage
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Tue Aug 06, 2013 2:07 pm |
| MrBSI wrote: |
| Edward wrote: |
Replacement cluster
OR
Replace the dodgy drive motor in your current cluster
OR replacement cluster & you can swop a part over from old cluster to retain the correct mileage, pretty sure the info is on the forum somewhere.
Posted: Tue Aug 06, 2013 2:13 pm |
Nice one guys! Cheers for the help
Posted: Tue Aug 06, 2013 2:28 pm |
| Jack123 wrote: |
I just changed mine, T Reg 1999, Got one from a 2000 car, You MUST get one with lower milage from a care before 2001, My mileage went from 100k down to 80k, so make sure you make a record of the old and new milage so you can always work out what the actual milage is.
The milage is stored in the unit, not the ECU, Atleast I don't think it is, when I changed mine the milage was 83000, and it didn't update to the cars higher, actual milage, so I'm pretty sure the milage is stored in the clocks. |
Just double-checked the log book there and the car is a 2001, is that going to make a difference to any of this?
Posted: Tue Aug 06, 2013 2:32 pm |
Your 206 is NON plexed as you have already said you have 2 connector plugs on the back of the cluster.
Posted: Tue Aug 06, 2013 2:34 pm |
| Jack123 wrote: |
Just double-checked the log book there and the car is a 2001, is that going to make a difference to any of this? |
Yeah ignore what I said earlier, You can get any speedo as long as it has two plugs, milage is irrelevant.
Wanted List;
Crystal Headlights.
Posted: Tue Aug 06, 2013 2:45 pm |
Yeah its got two multi-cable connectors out of the back, a yellow one and a white one. Does that mean, it doesn't matter about the year of reg then?
Posted: Tue Aug 06, 2013 2:55 pm |
| Yeah its got two multi-cable connectors out of the back, a yellow one and a white one. Does that mean, it doesn't matter about the year of reg then? |
Yes, It has to be pre-plex, which is pre-2001 I think, I always get it mixed up.
As long as it has two plugs on the back you will be fine, The one plug speedos are Multi-plex.
Wanted List;
Crystal Headlights.
