Online Now [376]:
Visitors: 375
Today: 30351
Total: 143448096
Forums › The Car › 206 Talk › Whats this plug?
Whats this plug?
Jack123
PostPosted: Tue Aug 06, 2013 2:11 pm Up
Searched the forums for any likely candidates but can't find anything, was removing a few bits from the car and noticed the foam behind the panel, pulled it forward and it has an orange plug in it, looks like there could of been two others in there at some point also, anyone know what its for?
Cheers.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
PostPosted: Tue Aug 06, 2013 2:12 pm Up
I reckon passenger airbag disarm switch, seeing as the plug is orange its most likely part of the SRS system.
Jack123
PostPosted: Tue Aug 06, 2013 2:15 pm Up
Ah, would make sense considering its location, if only I had a passenger airbag Laughing
Wanted List;
Crystal Headlights.
PostPosted: Tue Aug 06, 2013 2:28 pm Up
Most likely find the other plug is behind the dash above glovebox.
Fit passenger airbag, fit bulb to instrument cluster, change or reconfigure airbag ecu & job done.
Jack123
PostPosted: Tue Aug 06, 2013 2:31 pm Up
Cars coming up for 15 years old soon, so I'll either be getting rid and getting something newer, or replacing the airbag as its been 15 years, if I do replace the one, I may as well add the other, I'll have a hunt for that plug when I get the glovebox out to see if the plug is there for the glovebox light.
Wanted List;
Crystal Headlights.
PostPosted: Wed Aug 07, 2013 4:20 am Up
Ethernet.
