Latest: Beduff1977
Overall: 17134
Online Now [605]:
Visitors: 604
Today: 98823
Total: 108621902
Forums › The Car › 206 Problems › Got Air conditioning Re-gassed but still no cold air?
PostPosted: Wed Jul 24, 2013 9:12 am Up
If there's no gas in the system then the aircon compressor clutch wont cut it.
Doesn't sound much of an aircon specialist with a crap diagnosis like that.
Did they fill the system with nitrogen to test for leaks OR vac the system ouy to see if it will hold a vacuum, those are the 2 accepted tests to see if an aircon system is gas tight,
very_452001
PostPosted: Wed Jul 24, 2013 11:04 am Up
no they have not done the leak or vac test. Just the pressure test. lets say if it passes those tests and is gas tight then what problem do you think I have? Mechanical or electrical problem?
very_452001
PostPosted: Wed Jul 24, 2013 11:09 am Up
The system hasn't got a hope in hell of working until it's regassed, your wasting your time until then.
very_452001
PostPosted: Wed Jul 24, 2013 11:19 am Up
I had it regassed
very_452001
very_452001
PostPosted: Wed Aug 07, 2013 8:50 am Up
anyone? before this turns into a x file and im screwed
very_452001
Barking
PostPosted: Wed Aug 07, 2013 9:01 am Up
If you haven't done anything about it since you started this thread, you are unlikely to need the A/C anyway.
I got a dig bick.
You that read wrong.
You read that wrong too.
very_452001
PostPosted: Wed Aug 07, 2013 9:35 am Up
thanks for your help, anyone else want to reply with more helpful replies like this?
very_452001
Barking
PostPosted: Wed Aug 07, 2013 9:46 am Up
You appear to have ignored all the help so far, what other 'help' are you expecting?
I got a dig bick.
very_452001
PostPosted: Thu Aug 08, 2013 6:44 pm Up
yeah I ignored the advice to see a air con specialist hence i went to go to see one.
very_452001
PostPosted: Fri Aug 09, 2013 2:16 am Up
When you went to the "air con specialist" what did you ask them to do, and what did they charge you for doing? They haven't really told you anything that a bloke in the pub couldn't tell you
Odd that someone qualified to work on air con would only say there's no pressure and not mention why.
99.9% of people that offer a service would try and get the work to fix the fault by giving a repair estimate.
You should name and shame the company so that others know who to avoid in the future.
very_452001
PostPosted: Fri Aug 16, 2013 6:48 pm Up
yes its this company based in birmingham:
climate controllers
According to google reviews they are suppose to be the best in birmingham at the moment.
very_452001
very_452001
PostPosted: Wed Jun 18, 2014 10:12 am Up
Is the compressor and pump both mean the same thing?
The compressor/pump wont start until there's gas in the A/C system?
very_452001
mtempsch
PostPosted: Wed Jun 18, 2014 1:36 pm Up
Yes, as been stated previously in the thread.
There's a clutch that controls whether the AC compressor turns.The clutch is in turn controlled by a pressure switch as a safety feature (as well as the AC panel, but the pressure switch has priority).
No pressure -> switch off-> clutch does not engage-> AC compressor doesn't turn-> no cooling.
Silvermetallic 2004 206 RC
very_452001
PostPosted: Fri Jun 20, 2014 3:35 am Up
Ok so I cant rule out that its the compressor fault unless there's pressure in the system and that means getting it re-gassed with UV Dye to check for leaks. At this stage can I see the compressor is moving mechanically in the engine bay? If its moving that means compressor is working and i have a leak instead?
very_452001
mtempsch
PostPosted: Fri Jun 20, 2014 4:04 am Up
If it's actually spinning, beyond the point of the clutch, you either have pressure and thus no leak (or minute leak if recently regassed, so that pressure still hasn't dropped below the point of the switch. You should have cool air, barring some internal compressor fault beyond me.
Or the switch has failed in a way that causes the system to think there's pressure, so it engages the clutch and spins the compressor anyway. I'm not sure, but I believe that'd be bad for the compressor (the very reason the switch is there in the first place...)
Might be that someone somewhere could pull the compressor and test it outside the car, but for in car testing I believe the following is what's prescribed:
Step 1: check for sealed system (draw a vacuum and see that it holds) or pressurize with say nitrogen and see that it holds. Pressurisation with dye added would be step 1.5, in order to locate the leak(s) in case of vacuum or pressure not holding, but any decent AC tech would know their way about this.
Step 2: If leaking - [try to] fix the leaks then goto step 1...
Step 3: once the system holds pressure, refill with coolant gas.
Step 4: Check that the pressure switch is working (actually probably want to have measured it before and after/during pressure testing, so that a faulty switch could be replaced before the actual refill)
Step 5: Check that the clutch engages and compressor spins.
If it still doesn't make cool air, it's probably internal to the compressor and beyond me...
Page 4 of 5
