Latest: jackrox1992
Overall: 17186
Online Now [716]:
Visitors: 715
Today: 11123
Total: 148397876
Forums › The Car › 206 Talk › Terminals on a 206
Terminals on a 206
Forum Index › 206 Talk
Jordy6969
PostPosted: Thu Aug 08, 2013 2:50 pm Up
I've been advised to carry out a test to check if my map sensor is shot. Part of this test is to check the voltage with a multimeter across 3 terminals with different variables. However I don't know where these 3 terminals are on a 206....
I dunno if this is common sense but I've searched and can't find my answer!
If someone could let me know I can quickly carry out this test and find out the cause of my idling problem
This is the link to my idling problem thread for more info on it www.206info.co.uk/Foru...52223.html
Thank you
PostPosted: Thu Aug 08, 2013 3:09 pm Up
Or get someone with a parameter measuring scanner to check the manifold pressure.
Has it had any head work recently?
Jordy6969
PostPosted: Thu Aug 08, 2013 3:15 pm Up
That sounds expensive tbh. The multimeter solution appears easier. Someone must know where these terminals are!
Nah no head work I don't think as no receipts from past owners, been advised that it might also be the ICV but concerned that it idles completely fine when AC is on and when engine is cold. I have a rough idle after 5-10mins driving and with without AC on...
PostPosted: Fri Aug 09, 2013 2:22 am Up
It means test the actual sensor, so unplug it and you will see 3 pins (3 on the loom side but ignore that)
Then test it on those. I can put up more detailed information when I get home.
Personally when anything idle wise is concerned, I would make sure it's 100% not the ICV first.
Jordy6969
PostPosted: Fri Aug 09, 2013 2:30 am Up
When you say sensor do you mean the map sensor or idle control valve sensor or just mean in general.
Any tests to check if its the ICV other than just buying another one lol
Thanks for the insight mate!
PostPosted: Fri Aug 09, 2013 2:03 pm Up
What He Said
PostPosted: Sat Aug 10, 2013 9:22 am Up
In general for any 3 pin sensor, unless it shares a common ground in which case it would be 2 or even 1 wire (loads of different types it's impossible to generalize them all)
I've based this on a normal GTI.
Checking the ICV-
Disconnect the plug, if you can't get to the pins then disconnect the valve off the throttle body so you can hold it in your hands.
Measure the resistance over A + D and B + C. Both should be between 48 and 62 ohms.
I can get information on the MAP sensor if you want, but you need to check with the engine running. Apparently there are terminals you can use without unplugging it but I don't know of them off the top of my head.
Jordy6969
PostPosted: Tue Aug 13, 2013 6:19 pm Up
So disconnect the plug from the ICV and put a multimeter across the stated terminals ye? Or put a multimeter across the terminals on the ICV?
PostPosted: Wed Aug 14, 2013 5:14 am Up
The ICV, you are assuming there is correct power and earth signals so you are testing the actual sensor.
Jordy6969
PostPosted: Wed Aug 14, 2013 5:23 am Up
Ok cheers! So will there still be a voltage running through the ICV even though the plug is disconnected?
PostPosted: Wed Aug 14, 2013 6:04 am Up
The multimeter itself will provide the voltage, completing the continuity.
Jordy6969
PostPosted: Wed Aug 14, 2013 10:27 am Up
Ok thanks for the information pal.
If the resistance isn't between these numbers it's an indication of it being at fault?
PostPosted: Wed Aug 14, 2013 3:22 pm Up
Yes, it doesn't guarantee that it is fine if the values are correct but if they are well out then it can be assumed that it is functioning correctly.
