Online Now [1186]:
Visitors: 1185
Today: 184653
Total: 148942837
Forums › The Car › 206 Problems › Has anyone loaded the chinese version of pp2000??
206gt160
PostPosted: Fri Aug 09, 2013 9:36 am Up
Seem to be having trouble installing the disk onto my laptop.. I have the correct operating system to run pp2000
Does it have to be linked to the car on setup.
Any advise would be greatly appreciated
PostPosted: Fri Aug 09, 2013 9:44 am Up
You need to turn off your anti virus and internet connection before starting otherwise it screws up.
There are videos on you tube that guide you through setting it up. The activation requires information from PP2000 to be entered into the key gen. Make sure you read the text files on the disc so you enter the correct version and user numbers. These are different to the ones it shows on the video and set up guide that come with the disc.
PostPosted: Fri Aug 09, 2013 9:46 am Up
What He Said
Only downside to owning Peugeot Planet / Citroen Lexia is having to use crappy Windows XP to run it Shocked
206gt160
PostPosted: Mon Aug 12, 2013 2:39 am Up
Thanks guys i'll have another look at it tonight to try and sort it out.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
