Latest: lio94
Overall: 17181
Online Now [209]:
Visitors: 208
Today: 38678
Total: 141678380
Forums › The Car › 206 Problems › Cam shaft sensor location
LeeUK
PostPosted: Thu Aug 15, 2013 10:01 am Up
I've had my 206 at another garage regarding the misfire after the last garage didn't have a clue. This garage are saying it is either the cam shaft sensor or no3 injector.
Just trying to work out where the sensor is on the 1.4 petrol engine?
Also the garage say to change the sensor first as it is the cheapest but I'm thinking it is more likely to be the injector?
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
19Connor92
PostPosted: Thu Aug 15, 2013 11:42 am Up
get fault codes read first, but the injector is prop causing the misfire, the cam sensor fault will just be due to a nock on effect. £20 an injector to be cleaned and tested cheaper than buying a new one.
LeeUK
PostPosted: Fri Aug 16, 2013 4:59 am Up
Yeah they read the codes and there was two, one for no3 injector and one for the camshaft sensor.
Going to go with the injector first.
2001 206 1.4i GLX
2008 207 1.4 HDI
