Latest: tbafonso
Overall: 17130
Online Now [52]:
Visitors: 51
Today: 4983
Total: 103935420
Forums › The Car › 206 Problems › Air temp sensor
Air temp sensor
Deano
PostPosted: Thu Aug 15, 2013 7:45 am Up
Can some one show me a pic of where the air temp sensor is on the 140 plz
PostPosted: Thu Aug 15, 2013 11:59 am Up
On the front of the throttle body. Grey sensor.
Deano
PostPosted: Fri Aug 16, 2013 5:52 am Up
Thank you
Deano
PostPosted: Mon Aug 19, 2013 4:23 am Up
They is 2 grey sensors one on the top one on the bottom matey
Deano
PostPosted: Mon Aug 19, 2013 5:09 am Up
Bump some one plz help I puttin throttle bodi back on now need to know
PostPosted: Mon Aug 19, 2013 6:22 am Up
The only grey sensor attacthed to the alloy tube part of the TB is the AIT sensor.
Deano
PostPosted: Wed Aug 21, 2013 3:53 am Up
No they is one on the top with the little nipple thing we call it and one down below goin to a silver unit think I sussed it anyway decided to not put on scranned even more petty I trying to get petty consumption better thanks for help anyway
PostPosted: Wed Aug 21, 2013 6:43 am Up
Oh here it is...right at the top front of the throttle body.
PostPosted: Wed Aug 21, 2013 12:46 pm Up
Wow, that looks sparkling-clean. ^
