Latest: Worthy967
Overall: 17143
Online Now [501]:
Visitors: 500
Today: 72925
Total: 115406194
Forums › The Car › 206 Problems › fault code p0350 again
alane29
PostPosted: Sat Aug 24, 2013 11:10 am Up
Hello
I had code P0350 a month or so ago replaced the coil all was good until today same problem car cut out and was hard to start got home but only just was hesitating and on the verge of cutting out
Anyone got a clue why the coil would go again so soon after replacing it ???
alane29
PostPosted: Sun Aug 25, 2013 12:06 pm Up
update - spent some time on the missus car today and found the problem started the car I could hear water gurgling somewhere near the air box so I took out the air filter and it was soaking wet I then removed the complete air box to find the ducting had come apart and the bottom section had about 2" of water lying in there .
So I stripped it apart drained out all the water and put it all back together.
I reset the error code p0350 started the car went for a drive and its running perfect again.
I assume now that water got into the cylinders and messed with the plugs and coil .
She has been out in the car this afternoon and everything is fine .
