Online Now [1229]:
Visitors: 1228
Today: 235785
Total: 148990146
Forums › The Car › 206 Talk › Question on "Brake load sensing valve"
Forum Index › 206 Talk
Triggerfish
PostPosted: Thu Aug 29, 2013 12:56 pm Up
The "brake load sensing valve" has seized to operate due to rust so there are no movement.....my question is:
What is the allowable movement (or minimum/maximum movement requirement) for this valve?
There appears to be a spring hidden behind the actual angled bracket so it springs back and forward.
Leegsi
PostPosted: Thu Aug 29, 2013 3:28 pm Up
Soak it in wd40 or something like that and move it by hand till its free.
Have to do this quite often at work.
broadblaster
PostPosted: Thu Aug 29, 2013 3:48 pm Up
as above its very common fault come mot time.
on a back road playing
Triggerfish
PostPosted: Thu Aug 29, 2013 4:12 pm Up
Manage to apply some WD40 at it, it is now moving freely.....but only moves about 1 inches + or so / around 25-30mm.
Is that the furthest it will move? or does the actual angled bracket move some 90 degrees or so? which I don't think it can.
.....and what would be required to pass an MOT?
