Latest: lio94
Overall: 17181
Online Now [194]:
Visitors: 193
Today: 41672
Total: 141292022
Forums › The Car › 206 Problems › Stuck in 2nd gear!
Stuck in 2nd gear!
underdosed_420
PostPosted: Fri Aug 30, 2013 6:24 pm Up
Hope someone can help. My 180 is stuck in 2nd. Gear stick is sloppy and won't select any gears but car is in 2nd and clutch works so can still drive but everywhere in 2nd! Anyone know what this might be?
206 GTi 2006-2009, 206 GTi 180 2013-present
Tolkienfan001
PostPosted: Fri Aug 30, 2013 11:04 pm Up
Trade Rating: +13
Gear linkage?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Sat Aug 31, 2013 8:01 am Up
Cable gear linkage on the 180.
Get it up on the ramp & have a look.
cosmicdance
PostPosted: Sat Aug 31, 2013 9:03 am Up
Yes it does sound like the gear linkage.
Mine did the same thing and they do just pop back on, like a ball and socket fit.
Although this will only be a temporary fix as they will come off again at some point due to them being worn so I would get them replaced ASAP.
I have the Peugeot 206 1.4 HDi and I accessed the gear linkage by taking the air filter housing off.
Andy
Andy
underdosed_420
PostPosted: Sat Aug 31, 2013 9:51 am Up
Cheers for the help guys. What am I looking for as no garage open so need to sort it myself if possible before Monday!
Tolkienfan001
PostPosted: Sat Aug 31, 2013 9:55 am Up
Trade Rating: +13
Back of the engine right hand side from the gearbox to the middle of the car. 2 or 3 different length metal rods on mine. Not sure how many. Mr BSI says yours is cable though. They are easier to see from underneath.
2005 1.4 16v Sport
PostPosted: Sat Aug 31, 2013 12:36 pm Up
Easier from above id say. Remove the battery and box and look from the back of the gearbox, to the middle of the engine, above the exhaust manifold.
