Latest: cogeim7
Overall: 17185
Online Now [982]:
Visitors: 981
Today: 355
Total: 147738980
Forums › The Car › 206 Problems › dipped beams not working
bridge9
PostPosted: Mon Sep 02, 2013 5:53 pm Up
hi guys,
any one had this problem? dipped beams stopped working, bulbs fine fuses fine and all other lights working ok?? a friend said it could be the relay but can't find any thing on this in the manual. how do I find and check relay? or is there a different cause? thanks oh it's a 2004 206 1.4 diesel Confused
gazza82
PostPosted: Tue Sep 03, 2013 4:41 am Up
Have you got one h4 (patterned lenses) or two h7 bulbs (clear lenses) in your headlights ?
I don't think there is a relay on the headlights ...
bridge9
PostPosted: Tue Sep 03, 2013 4:02 pm Up
hi thanks for reply, not sure what you mean, i have two bulbs in each light, one for dipped beams and one for high? is that what you mean?
i took two photo but can't seem to post them in this message. i'll stick them in my profile and maybe you can have a look there if you get time. thanks again
PostPosted: Wed Sep 04, 2013 3:50 am Up
It's the double optic headlamps (H7). Possibly a faulty com unit.
Try a BSI reset to see if it solves it, the other option is to find someone with PP2000 and see if that throws up a fault with the com unit.
bridge9
PostPosted: Wed Sep 04, 2013 10:58 am Up
thanks macca, i'll look into that, not sure what a BSI reset is or a com unit!!!! but i'll find out! thanks again
PostPosted: Wed Sep 04, 2013 2:20 pm Up
Beginners Guide to the 206
bridge9
PostPosted: Wed Sep 04, 2013 5:31 pm Up
ah that's class thanks! loads of info there. Razz
