Latest: Beduff1977
Overall: 17134
Online Now [888]:
Visitors: 887
Today: 124492
Total: 107305225
Forums › The Car › 206 Problems › Peugeot 206 external temperature sensor addition??
Aris
PostPosted: Wed Sep 11, 2013 12:11 pm Up
Hi. Recently i changed the clock display screen of my P.206. The new one is from a newer model so it has an outside temperature sign that is not working. So i would like to ask if anybody knows:
1. Can i connect a temperature sensor on my Peugeot, a new spare part?
Question Question Question Question
2. Where do i connect the wires of the sensor? Is there a ready input on my car that i can connect it? And where is that?
My car is a 2002 P206 1.1 60hp
The sensor i think is that: www.ebay.co.uk/itm/NTS...257e09d5d0
Thank you in advance
marv88
PostPosted: Wed Sep 11, 2013 1:56 pm Up
im pretty sure the sensor is the driver side wing mirror
Tolkienfan001
PostPosted: Wed Sep 11, 2013 1:57 pm Up
Trade Rating: +13
Passenger side...
2005 1.4 16v Sport
Check out my 206 here!
Only if its a left hand drive 206.
Aris
PostPosted: Wed Sep 11, 2013 3:06 pm Up
Thank you for answering
My car its a left hand drive 206
The question is that in my car there was not an external temperature sensor, so i just ask if anybody knows, if i can connect one on my car, in order to work the temp. sign on the new screen.
It would be very helpful for me if someone could look and tell me or show me in a photograph where the wires of the sensor are connected. I know that is not an easy work but every help you could give me would be useful
gazza82
PostPosted: Thu Sep 12, 2013 6:15 am Up
You can try but I bet the BSI will need updating and even then it may not work. I guess it depends if your car has the wiring from the door mirror to the display, etc.
Aris
PostPosted: Thu Sep 12, 2013 8:35 am Up
gazza82 do you know where the wires are connected?
Are they connected on the right's door plug? Or the wires of the sensor come from the ECU?
Thank for your reply
gazza82
PostPosted: Thu Sep 12, 2013 8:57 am Up
Not sure but I'm betting they are just inside the mirror and they connect to the loom using the mirror plug. The wiring to the ECU will be there already from the mirror/door in the loom (or not as the case may be!)
Peugeot to save money tend to have one loom for each model of car*, so likelyhood is the wiring is there but you will have to tell the BSI unit that the sensor is in or it just ignores it. You have a 2002 model so it's probably the multiplex wiring system which means many of the sensors and parts share the wiring and the BSI computer works it out.
* Not always true as the loom in the 180 GTi I think is different as are the multiplex and non-multiplex looms.
