Online Now [387]:
Visitors: 387
Today: 33421
Total: 142543878
Forums › The Car › 206 Problems › Car engine starts and then the engine cuts out
Charlesb89
PostPosted: Thu Sep 12, 2013 12:56 pm Up
Dear Peugeot community
Car 206 Diesel 51 plate
Hoping for help/advice with the problem below,
The car starts first time, recently had a new battery fitted, but after around 10 seconds the engine cuts out.
I try to re start the car, engine whirls but doesn't take. I repeat this 3-4 times and then the car starts, no further problems are experienced until the car is left for 12hrs+ and then the problem repeats
I have very little technical knowledge of cars so any help/suggestions would be gratefully appreciated
Charles
PostPosted: Thu Sep 12, 2013 4:21 pm Up
well it would be be better to have a fault code read before any suggestion,but from what you Said,I would say you have a problem with the fuel pump or Fuel Pump pressure sensor/s,that makes the fuel cuts off after a while.
PostPosted: Thu Sep 12, 2013 4:30 pm Up
Start by getting the fault codes read.
Charlesb89
PostPosted: Mon Sep 16, 2013 3:33 pm Up
Thanks will do
PostPosted: Tue Sep 17, 2013 9:09 am Up
Which one of the 3 diesel engine's that could be fitted to a 51 plate 206 are we dealing with then?
1.9 diesel?
1.4 HDI?
2.0 HDI?
Knowing what engine we are dealing with helps a lot.
