Latest: morgan20
Overall: 17135
Online Now [606]:
Visitors: 605
Today: 56630
Total: 110608669
Forums › The Car › 206 Problems › Wheel cylinder nut/connection and pipe issue?
Go to page Previous  1, 2
Triggerfish
PostPosted: Fri Sep 13, 2013 3:16 am Up
Well macca1411: these images are very interesting indeed. From what I can see, the second image has the compensator (item 17) which would apply to my car exactly as it is.
The actual part of the pipe I've been talking about is item 15, which is a copper pipe (black coloured) links from the wheel cylinder(back wheel shown) to the flexible pipe/hose (item 2). Although your image does not shown item 15 description bit which may be hidden.....and I wonder if you would be kind enough to scroll down that text section on the right hand side to show what the exact description of that item 15 says with the relevant part numbers etc......so from what I can see from the image, peugeot can and should sell them.....BUT?
The advice I got from my local peugeot dealer were they do not sell such pipes and suggested I would need to buy a roll of copper pipe, fittings and special tools (to make flares) or take it to a garage and they will do it for you.
I noticed there are people in ebay willing to makes brake pipes up to your spec.
206: 1.1L, 2002.
PostPosted: Fri Sep 13, 2013 4:20 am Up
4886A7 £6.52
Don't bother with ebay. Garages can make them up. At least then you can make sure that it's right by comparing it with the old one before you pay.
Triggerfish
PostPosted: Fri Sep 13, 2013 4:58 am Up
"4886A7 £6.52".....only £6.52!!.....I wonder why my local dealer can't sell it to me?? ok, going to take the entire pipe to a local garage and see what they can do.....report back later.
And thanks to all responses so far on this thread, they have been very helpful.
206: 1.1L, 2002.
Triggerfish
PostPosted: Tue Oct 01, 2013 1:49 pm Up
done now, £10 at a local garage to supply and bend the copper pipe to match existing with flare nuts at either side......now fitted to the car, bleeding done.
Thanks everyone for their help!
206: 1.1L, 2002.
Page 2 of 2
