Latest: Puggingalong
Overall: 17129
Online Now [269]:
Visitors: 268
Today: 14662
Total: 101221853
Forums › The Car › 206 Problems › Dipped beam too low? But no MOT advisory
smiarmstrong
PostPosted: Sat Sep 21, 2013 7:33 am Up
Recently MOTd car with 4 advisories, none which included the headlights. I fitted some of those good Phillips headlight bulbs. The car is a 2000 1.4 LX. The dipped beam seems to be concentrated on the road directly in front of the car, when compared to other cars on dipped they give more view of the road ahead. It's quite annoying on unexpected corners! I've tried to adjust using the little white plastic screw but they haven't moved. Could do with lifting them slightly any ideas? I've refitted them twice to double check they're fitted correctly. I don't feel I'm getting the full benefit of a 30 quid pair of bulbs !
206 1.4
tsotd
PostPosted: Sat Sep 21, 2013 12:30 pm Up
have you tryed the auto ajuster inside the car? (if your model has one)
did you have the clear lights or frosted?
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
gazza82
PostPosted: Sat Sep 21, 2013 3:12 pm Up
And are the bulbs in the right way up?!? Sounds silly, but it is possible to insert them the wrong way up!
smiarmstrong
PostPosted: Sun Sep 22, 2013 10:40 am Up
Yeah the auto adjuster is all the way up! Gazza I've checked twice now that the lugs are properly aligned with the 3 recesses, the bulbs are seated correctly.
Tsotd do you mean the headlight lenses themselves? They are frosted if I understand you correctly!
Thanks lads
206 1.4
tsotd
PostPosted: Mon Sep 23, 2013 9:35 am Up
normaly the frosted headlights are dimmer than the clear ones,
