Online Now [560]:
Visitors: 559
Today: 28888
Total: 145508002
Forums › The Car › 206 Problems › central locking problams but no key fob...
evans125
PostPosted: Sat Sep 21, 2013 4:48 pm Up
Hello ive just got a 2ltr hdi, I Have no key fob and I carnt seem to get the central locking to work with the key in the door... It will just lock what ever door the key is in and that's it ! Don't have a owners manual so don't know what fuses to check. Need to sort it asap as it also means my boot is never locked. Any help would be great.
PostPosted: Sat Sep 21, 2013 5:45 pm Up
Fuse list is on here somewhere, what do you mean you have no key fob? The boot can be locked from within the car.
evans125
PostPosted: Sun Sep 22, 2013 5:13 am Up
The car has central locking but I have no fob with a button on to press for the doors to lock just a standard key. when I use the key in the door it will only lock the door that the key is in and not all of them. And I have no button on the inside that I know of to lock the boot. Have looked for the fuse box diagram but carnt find it. if you could post me the link that would be great.
PostPosted: Sun Sep 22, 2013 5:45 am Up
To lock the boot you'll need to pull the back seats down, remove the black plastic cover from inside the boot, and you'll see a metal bar you need to slide over. Without a key fob I think that's how your doors will lock.
