Latest: Beduff1977
Overall: 17134
Online Now [110]:
Visitors: 109
Today: 102463
Total: 107092390
Forums › The Car › 206 Problems › No compression
No compression
Deano
PostPosted: Sun Sep 22, 2013 6:38 am Up
Hi I was driving to work the other day when my 206 Gti 140 02 reg decided it had enough and broke down when I tryyed to start the car it was just turning over flat so I thought the cambelt had snapped when I towed it home I took cover off cambelt put it in gear and jacked it up turned the engine by hand and watched the belt the belt is not snapped and all the teeth are still on so I put a compression tester on and they is no compression registering has anyone got any ideas I though maybe the belt might of slipped ?
richpowell91
PostPosted: Sun Sep 22, 2013 6:48 am Up
Have you tried pinning the pulleys to see if it lines up. Although if youve got no compression on any of the cylinders youve lost nothing by taking the head off and having a look.
Deano
PostPosted: Sun Sep 22, 2013 6:58 am Up
Ok I say the valves are damaged and it needs new head I have another engine in the garage what seazed due to a broke sump and all the oil leaking out will the top head still be ok on that engine or will it be fxxked
richpowell91
PostPosted: Sun Sep 22, 2013 7:02 am Up
I would say you would be damn lucky for the head to be any good if the bottom ends f****d. Take the cam covers off and have a look at the state of the cam lobes and can journals. But again you haven't lost anything over than your time it takes to whip the head of the spare block to have a look.
Deano
PostPosted: Sun Sep 22, 2013 7:12 am Up
Thank you for your help mate much appreciated I will have a look might just look for a low mileage engine bang that in them get rid gutted though love that car
Deano
PostPosted: Sun Sep 22, 2013 1:22 pm Up
Does anyone have any low mileage 206 engines?
